Question about Harman Kardon HK206 Computer Speakers
Well we had it hooked up a long time.disconnected it about a yr ago.Tried to get it to work to day and it would not.Do you think i need instructions on how to hook it up or download something for it to work or what.please help
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 31, 2011
I had my WNDA3100v2 working smoothly for the whole year. Somehow 2 days ago, it didn't find any network and completely disconnect. I have tried to uninstall/install several times but it didn't...
I doubt it's your software- I think that either the network cable or ethernet card if wired, wireless ethernet card if not, has gone bad. I'd see if you could get a known-good cable and card/s to see if that is true
Jun 13, 2011 | Computers & Internet
My refurbished Garmin Nuvi 275T will not start up, and stays blank. It was fully charged and working a few days ago. I have tried a soft and hard restart unsuccessfully. I also tried hooking it up to my...
I think you need to update your Garmin GPS. if you need any type of help about updating ask here. There is a website which shows how to update garmin gps shown below.
Garmin Map Updates
Sep 22, 2017 | Garmin NUVI 270 GPS Receiver
10 yr old, sits in a garage. Worked fine until a
is the fan operating,if so then check your damper vent door that throttles cold air from freezer to refrige compartment they can freeze shut and a hand held hair dryer will thaw them out,then adjust its control to make sure the door moves when control is adjusted
May 08, 2010 | Kenmore 72102 / 72104
I have the Kodak 5300 All in one easy share printer. Less than a yr old. Also a Del computer with Vista Operating system, Less than a yr old. About a week ago decided to take the time to learn the kodak...
try using the system restore option on Dell computer.........as you have vista,,,click on the start button and type system restore in start search box and follow the on screen instructions and select yesterday's date and proceed.......should help:)
Apr 16, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How install wiring system for trailer hook up
You have to purchace a wiring kit i got mine at northern tool
a hot line has to be run from the battery the rest you follow instructions with kit took about 20 min
do not just splice into wires not enough current from relay
did  about 7 yrs ago workes fine i tow 3-4 times yr 2-3k trailer no problem
JR23
Apr 09, 2009 | 1999 Ford Explorer
Disc Read Error message...
You could try flashing the firmware..just a shot in the dark, but what the heck, you got nothing to loose. Instructions can be found at the PS2 website.
Oct 22, 2008 | Sony PlayStation 2 (PS2) Console
Xtreme sound wms303 cd player..... need a new one?
It sounds like if it only works a day or two and then you disconnect it and re-connect it, and it works again for a day or two, I don't think the problem is how you are connecting it. I think the radio needs to be reset every couple of days. If it has a reset button, just press that and it will at least keep you from disconnecting it and reconnecting it.
This also sounds like it has an internal electronic problem. When you disconnect the radio, it resets the microprocessor. You should have it checked out by a service center, or if you do not want to spend any money on this radio, just get a new one.
Jul 06, 2008 | Xtreme Sound WMS303 CD Player
65 Inch Samsung Projection TV- Shaky Picture
have a tech look at your tv it needs to be repair checks can be made in the power supply.video circuit,or the IF CIRCUIT.good luck.
Apr 01, 2007 | Samsung HCN653W 65" Rear Projection...
Harman Kardon HK206 Computer Speakers Logo
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
