I have a RCA V5220 handheld digitial recorder. I would like to know if I transfer my recorded files from my recorder onto my computer, will that automatically erase these files from my recorder?
  • 17,970 Answers
We dont have the manual for your model, but it's easy to download your recorded files to your PC or laptop. Simply use the flip-out USB port or supplied USB cable to plug into your PC. Turn your RCA recorder on and your computer should immediately recognize it as a portable drive.
Then, open the drive and you should be able to access and edit any file that is saved in the device. You can drag, drop, copy and move files at your leisure.
Keep in mind that if you "move" the files is the same that "cut" or delete, so, just use copy/paste task.
Hope helps.
Posted on Mar 31, 2011
How do i get the recording onto my mac?
if you can connect via USB try that first. Your computer will see it as a storage device and give it a drive letter. you can open it up and selet all the audio files and move them to a folder (you assign) on your computer. If you don't have a way to hook up via USB you can reord the audio file into your computer by hooking up to the earphone jack on the recorder and the to the Pink audio in jack on your mac. open the software that you use for recording audio (garage band for example, or sound recorder). you will have to do this is "real" time however so if you have a lot of recordinng on the device it may take awhile to get the all transferred.
Mar 22, 2011 | RCA VR5220 Digital Voice Recorder
I have an rca rp5022 voice recorder and when I attempt to transfer the files over to my computer an error screen pops up stating the file is corrupted and unreadable. I can listen to the file on the...
the files on your voice recorder is actually corrupted just as the computer is indicating.
I don't know how important these files are to you but I'm afraid you might loose them because they are corrupt.
To fix this problem, you need to format the recorder and by so doing you will loose all your files but the recorder will be okay. You will have to put fresh files on the recorder.
Your computer may have been the one that corrupted the files on your recorder.
To format the recorder, while the recorder is connected to your computer, click start menu, go to computer. You will see a drive representing your recorder, right click on the drive, scroll to format and click it. This will format your drive and your recorder will be fixed.
Note, that you will loose all the files on your recorder in the process of formatting.
Good luck.
Sep 23, 2010 | RCA RP5022 Digital Voice Recorder
Transfer digital recording to computer to make CD
As there is no USB port on this IC Recorder, you can connect the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Sound Recorder Software to capture the files. You can also use the Sound Recorder Software preinstalled in the Computer. After transferring the recordings to the Computer, you can use any CD Burning Software to burn the files to a CD.
Feb 19, 2010 | Sony ICD-B5 Digital Voice Recorder
Cannot transfere files from the recorder onto my computer
i had the same problem, but it was because i had only updated the drivers for the recorder, but did not install the file transffer software onto the conmputer..You need the program "Digital Wave Recorder" to enable you transffer files onto your computer..
Cheerz..
Jan 20, 2010 | Olympus VN-4100PC Digital Voice Recorder
RP5022A Handheld RCA Digital voice recorder
there is a link to a complete user's/instruction manual (PDF file) under "Product Details" here:
http://www.amazon.com/RCA-RP5010-Digital-Voice-Recorder/dp/B00006LEJ9
Sep 29, 2008 | RCA RP5010 Digital Voice Recorder
Dowloading audio files onto my computer..
I have an Olympus recorder. I don't know if the software is similar but their software has a way of copying the files to folders in the software. These files can then be used in other audio programs such as ITunes if you want to transfer it to your Ipod or audio recording software so that you can drag and drop them into one file.
If you look in the folder where your voice manage software is, is there a folder where the audio files are being stored within the program?
Jul 16, 2008 | RCA RP5010 Digital Voice Recorder
Move recording to my computer
plug it in, navigate to the files, drag them over. But the real problem then begins . . . now you must convert them to a playable file type and if you've got a mac you're screwed.
Mar 31, 2008 | RCA RP5020 Digital Voice Recorder
RCA RP 5012B digital recorder
It is not possible to download the sound files in their digital forms with this model of recorder. The only way to transfer the recordings is to connect a male-to-male 3.5mm (1/8") plug from the recorder to the line input of the PC (as was formerly mentioned) and record it onto the PC in real time. I've done this with mine and it works fine...it just takes longer to do than tranferring the actual digital file to the PC. A good MP3 recorder for the PC is Audio Record Wizard. http://www.nowsmart.com/arwizard/
The full version costs $25, but I think it's worth it.
Nov 01, 2007 | RCA RP5012 Digital Voice Recorder
44 people viewed this question
k24674
jasbo
jasbo
