The error message about invalid path is referring to a missing logo file. In the footer, or header, set Logo to None, or find the missing .bmp file and place it in your default SureTrak Clipart folder and re-browse to its location.
If the program can print to a normal printer, then all you need is to download and install a 'pdf' printer such as PrimoPDF. Then when you print from within SureTrak, just choose the PrimoPDF printer instead of your normal printer and it will send the output to a PDF file. :-)
Thats because the primavera program that you are using is a old version or it is a educational version. Update it to P-3.1 and then give it a try again.
There is no way that I know of to directly convert a .prx or .xer file to PDF. If you have SureTrak installed on your machine you could just buy a PDF writer and print it to your desired plot size. Then print it else where.
Had a similar problem with printing from a file saved on a network drive. Apparently the file name was too long. Moving a copy of the file to the local drive (such as a folder on the desktop) allowed printing. I believe I am also functioning without the Suretrak 3.0a or 3.0b software patches which may correct the problem (see Primavera's website for patch b). Since it is only on certain files, I would think it is due to too long of a path to the filename.
