Question about Kenmore Refrigerators
Kenmore fridge leaks water and stops cooling. Tech came out and said it was a heater/defroster unit that would cost $500. Sounds correct?
  • 1,543 Answers
$500 for a defrost heater replacement? Rip off city ! Don't know for sure what prices are in your area, but around here, that's about 3x what it should be.
Posted on Mar 31, 2011
  • Randal Ferrara Mar 31, 2011
    I talked to the owner of the company and he stated it was a circuit board and it cost about $250.00. The rest is labor. Does that sound reasonable.
  • Carl Schulzetenberg
    Carl Schulzetenberg Apr 04, 2011
    $250 for labor to replace a circuit board? Do it yourself for $0 labor.
Refrigerator stopped cooling. As close as I can tell the fan in the freezer part was frosted up for a length of time and has possibly ruined the fridges cooling fan? Kenmore model 106 freezer on top.
If the fan in the freezer stops, then coll air from freezer will not pass from freezer section to fridge section.In that case, the freezer section will get over frosted but fridge section will not get cold, because cool air will not pass from freezer to fridge.The fan is there for two things, 1) for cooling the heating evaporator coil and 2) For flowing the cool air from freezer to fridge.---------- If the frost is getting collected and fan is getting stuck up in frost, then this is the problem.The defrost cycle is not running, the cooling cycle is running.---------------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 18, 2011 | Kenmore Refrigerators
My fridge is leaking inside. I have a top freezer model and the leaking is happening in the lower fridge compartment in the rear, from above.
The defrost problem.The unit is not defrosting on time.--------
. First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
Jul 08, 2011 | Kenmore Top Freezer Refrigerator
Ice forming in the top freezer, leaks in the bottom refrigerator section
Sounds like the defrost circuit of your fridge has failed. If you remove the back panel of the freezer compartment, you will see the evap coil encased with ice. Normally the defrost circuit will turn off the compressor and turn on a heater to warm the coil to about 45 degrees to melt any frost build up. After about 40 minutes the compressor will kick back in to keep your fridge cool again.
The typical failures are that the defrost heater burns out. If you have an older fridge, the defrost timer fails to advance, causing the fridge to stay in cooling or defrost mode.
May 27, 2011 | Kenmore 18.2 cu. ft. Top Freezer...
Kenmore fridge leaks water on floor and then stops cooling. Tech said it needed heater/defroster and would cost $500. Does this sound right.
Ah no. If the fridge was not defrosting then water would not be leaking out.
It sounds like the defrost timer is not completing it's cycle. You may need a new defrost timer.
The cost of a new timer, call out, fitting and testing could be around $375
Mar 31, 2011 | Kenmore Side by Side Refrigerator
Freezer and fridge not cooling. if i unplu unit for one day and plug back in it works for two weeks and then stops cooling again. Aslo a lot of water leaks from bottom when i uplug it
You have a problem with the defrost system. It could be a few things defrost heater, thermostat, or defrost timer. It works for a few weeks then the evaporator coil is icing up (stops cooling) then you unplug and thaw it out(lots of water) Here is a link that should help Refrigerator not cooling
Click on the links in the troubleshooting and they will bring you to videos on repairing this.
Sep 20, 2010 | Maytag Refrigerators
Fridge not cool enough but frosty at the back
Since you are getting frost in you frost free refrigerator, tell me that the defrost circuit has a problem. It is made of a defrost timer/module, defrost heater and defrost thermostat. What should happen is that the defrost timer should periodically turn off the compressor for about 30 minutes and turn power to the defrost heater via the thermostat. The heater is attached to the evaporator coil and melts any frost build up on those coils.
It sounds like the defrost circuit has not been working for a while because the ice build up is not allowing the air to circulate around the coils to cool the refrigerator. The typical failures to the defrost circuit are the defrost timer motor fails to advance, or the defrost heater burns out. Hope this helps you.
Jul 14, 2010 | Kenmore 64802 Top Freezer Refrigerator
Kenmore top mount refrigerator freezer, ices up, water leaks through fridge vents, then freezes on fridge shelf. Automatic defrost issue?
sounds like could be defrost timer or heater issue...when in doubt contact a pro
if you need a part try www.appliancepartssolutions.com
Jan 16, 2010 | Kenmore Refrigerators
Refrigerator stopped cooling & freezing
2 possibilities here, the defrost system has mailfunctioned, this is realitevitaly cheap to fix, 2 parts are most likely at fualt, The defrost timer or the defrost eliment, failing it is either of the previously mentioned you may have had a brazed joint failure and the gas has leaked, with domestic fridges if a gas leak has occured it is usualy cheaper to replace the entire unit.
Should it be a part of the defrost system how ever then it is best to have it repaired, to find out which you will need a fridge tech to come and see it in person!
Aug 28, 2009 | Kenmore Refrigerators
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
