Question about Mitsubishi Televison & Video
I have a 2007 73" Mitsibishi 1080P DPL HDTV. I am
  • 28 Answers
This problem should be reported to the shop from where u havebrought it
Posted on Mar 31, 2011
42 Philips tv won't turn on just blue light flashing
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Sep 10, 2015 | Philips 40PFL4706 40 LED-LCD TV - 16:9 -...
Vizio e420vl screen whitish gray with black line, please help :(
mine did this I was told to pull out he plug and let it sit for about 20 minutes then plug it in. Hold the power button in for about 12 seconds to reset the television. worked good. oh keep your television away from AC s open windows. moisture can kill any electronics with just a few minutes of damp air.
Apr 21, 2014 | Vizio 42" E420VL 1080p 120Hz Widescreen...
When i turn tv on, visio 37" 64hz 1080p HDTV, it
The Vizio 1080P HDTV offers a variety of features and input jacks that make it a true multimedia centerpiece. Occasionally, however, there are a few scenarios in which the screen blacks out.
  1. Basic
    • Verify that all input cables and your power cord are firmly inserted. If you are viewing a program that utilizes RGB (red, green, blue) or HDMI cables, be certain your TV is not in sleep mode. It will time out and appear blacked out in this case. Verify your sleep timer hasn't been turned on. Try resetting the TV by turning it off for 30 minutes.
    Advanced
    • If you experience limited or no lights, the power supply is likely failing. If you feel comfortable doing so, open the back of the TV and look at the power supply area (shock hazard). Follow the power cord area to find it. Check for bad capacitors, which look like small batteries with connectors soldered to the board. They will be blown or bulged out. Replace them or the complete power supply.
    Other Considerations
    • Verify your surge suppressor is not bad. These often have a connected equipment guarantee that covers your repair if a power surge caused failure. You can reset all settings to original modes by pressing "Reset All Settings " in the Setup menu.
Oct 05, 2011 | Vizio VX37L Television
When I try to boot it is says," protected by a password authentication system ".
It may be a BIOS password, try using a default password list like this one http://www.phenoelit-us.org/dpl/dpl.html
May 31, 2011 | Computers & Internet
I am getting a blue screen that says mode not supported when I try to view HD channels
This usually indicates that you are trying to watch a screen in a higher resolution than the Tv will actually handle
Aug 17, 2009 | Televison & Video
Blue-ray Player HDMI jack to existing TV DVI-HDTV connector
Unless your TV is HDCP compliant (sorry, don't have to research this for you), you may not be able to watch Blu-Ray movies from your Blue-Ray player in 1080p. So first find out if your TV can do HDCP via the DVI port (i doubt it). If it can, you can get an HDMI-to-DVI adapter (you can find them real cheap off Amazon.com)
-Eddie V.
Dec 31, 2008 | Denon AVR-485 Receiver
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Televison & Video Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
