Question about Kenmore Refrigerators
Model # 106.54606300 not cooling on either side, cold air seems to be coming out of bottom air flow vent
  • 6,993 Answers
when your say "not cooling from either side...." do you means both your refrigerator and freezer is not cooling? If yes, please read further;
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Good luck.
Posted on Mar 31, 2011
Kenmore model 596 72913200 freezer works but fridge not getting cold
This will be an air flow problem from the damper failing. Usually what happens is, the air vent is not allowing air to pass at the damper due to the motor not opening and allowing the cold air to pass into the refrigerator side. A good way to check it is, to feel the amount of air coming out of the vent between the freezer and the refrigerator. If the air flow seems slow, or no air at all, replace the damper to restore air flow to the refrigerator.Here is the part you need to order.
The part comes with a 365 day, any part, any reason return policy.
Regards,
Richard Roth
http://appliancecafe.com
Nov 12, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Refrigerator does not cool below 50. Freezer side is ok
all cooling comes from thefreezer, lower down air flow to freezer and increase air flow to refrigerator, this should help.
Apr 08, 2011 | Admiral 26 cu. ft. Side-By-Side...
Freezer is working fine. The refrigerator is not
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | KitchenAid KSCS25FKSS Side by Side...
Freezer works, fridge side not cool
OK if the fan was replaced and the vents are open there has to be a restriction of air flow over evaporator coil causing the lack of air flow. On some models like yours there is something called an auto damper between the freezer and fresh food compartment and the damper is operated like a thermostat bulb on it's own solo. The best way to test them is to remove and place the thermostat bulb or tube coil into cold or hot water. I will gather more information for you as we go along here. Thanks, Sea Breeze
May 14, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
The temperature reading on the outside door panel flucuates
Could be a fan problem, open the door and hold the door switch in, the fan should start and you should be able to feel air coming out the vents (air flow is not very strong as it comes out many vents so you will feel a cold breeze rather than a strong air flow if it is normal. Also check if you can see any ice nuild up in the back of the freezer as it may be a defrost problem and the air can't flow due to the ice build up, if this the case it will need to be looked at.
Apr 18, 2010 | Samsung RS2578BB Side by Side Refrigerator
Ge refrigerator model gss22wgph bb
Carben,
I have the same problem and I am able to resolve it by defrosting the element which is behind the inside rear panel of the freezer. I use a hair dryer to melt the ice build up. It happbed a couple of times so I know that there is a cause for this which may be the defrost heater but I am not sure how to confirm this. Let me know if you have any ideas.
Aug 20, 2008 | Danby (DAR604BLS) Refrigerator
Refrigerators Logo
141 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
