Question about Vacuums
I have a Durbrand Canister Vac, Model #C2006 and need a replacement hose for it. Also could use a new floor attachment.
SOURCE: Fantom Canister Vacuum parts
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12055&thid=723654
Posted by jaybird73 on Jun 30, 2008
Hi, Don. I'm in need of a part for my Fantom Canister. It's a little difficult for me to describe but here goes...the part is the small metal "pins" that are found in the connection between the hose and the motorized floor attachment. There are normally 2 found in that area, they are about an inch long and I guess they pass the electricity between the hose and attachment. Any help is appreciated.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sound so me that it could be a lower wand with the pins in the end or the part of the power nozzle and the part that the lower wand fits into is called the gooseneck and that can be replaced as well. If it is part of the hose then you may have to replace the hose and that could be expensive or over $100.00 or more, as an estimate. The best place to get the information is the owner’s manual under trouble shooting or to cal the Fantom factory of which I will provide for you @ the bottom; or your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.fantom.com/ Customer Tech Support 1-800-798-7398
Hours are Monday thru Saturday from 9:00 AM to 6:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jul 03, 2008
MrScary66613
  • 1990 Answers
SOURCE: Craftman Canister Wet/Dry vac- Motor just stopped working
It is Repairable But, The parts will cost almost as much as a New Vac. I would just get a New Vac and save the Hastle and the Cash. The choice is all yours Though. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
CorvetteKing
  • 108 Answers
SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
Posted on Jun 05, 2009
  • 190 Answers
SOURCE: How does the upholstery cleaning hose attach to
See if this manual helps:
http://www.hoover.com/pdfs/manuals/F5857955.pdf
Posted on Oct 03, 2009
cpl50scpd
SOURCE: Kenmore canister model 116.25512 won't start
yes sears has the part if you search it on their website but the switch is included with the wiring harness for the powermate handle. total with shipping is over 37.00. i just need the switch and cannot find one sold separately anywhere.
Posted on Dec 25, 2009
When vacuuming hardwood floor, hair gathers on brush and never sucks into vacuum. I spend most of my time cleaning off brushes. How do I clean hardwood floor with dog hairs.
1. Broom and dust pan, then mop
2. Wet dry vac with wide non-brush attachment
3. Here's a link to a vacuum professing to clean pet hairs well
http://www.evvive.com/shop-by-brand/miele-open-box-canister-vacuums/miele-s516-cat-dog-vacuum_2
4. Try to find a wide attachment for the hose that has no brush, maybe something from a wet dry vac.
5. Take your dog outside and brush every day. It helps, but no matter what you do, you will have pet hair if you have an indoor pet.
6. Go to the source. See if your dog will be vacuumed. Half serious on this one.
Mar 14, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
I have a Harmony vacuum and need it only for bare floors. The attachment I have seems to be too rough on the floors. I just need a simple attachment with soft bristles for a bare floor that will fit this...
Take the lower portion of your wand to a vac shop and ask for a universal fit wide floor brush with NATURAL bristle. The soft bristle is much better quality and will clean deeper into grooves in your wood floor or and tiled area.
Dec 26, 2009 | Electrolux Harmony Canister Vacuum -...
The vacuum works on carpet mode but not floor and only when the wand is attached to the floor brush otherwise it does not work at all
Please define "works" on carpet mode" do you mean when you say it does not work at all, that it does not run, or does not have suction.
This sounds like the symptom of a clogged hose with blockage like this another vac needs to be used to draw things back out of the hose the way they went in.. Remove the hose and try dropping a penny through it . If there is an obstruction the penny will stop at that point and rattle inside the hose.
With a blockage at the hose, your power head will still lift lint and light soft dust, it will appear to have suction because the brush will sweep but the dirt will not go all the way through the hose.
Please post back to clarify if this is a vac that does not run or simpley has no suction
Nov 04, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
I have a Kenmore Canister Vac. I need to replace
Try forcing a flathead screwdriver between the flange (tab) on the hose collar and the tab on the swivel assembly itself, taking care not to gouge the wires. Saw one solution where they used 2 screwdrivers simultaneously; couldn't do that, but did loosen one side at a time.
Sep 24, 2009 | Kenmore Vacuums
Every time I turn vac on with hose attached the canister sucks in on itself. the hose is not plugged
Try it with no attachment or nozzle on the end. If it sucks the hose in on itself then, you'll be wanting to check that hose one more time. Pass something with a larger diameter through it. I'd try 3/4" PVC pipe or something like that. Another alternative is to place the hose on the exhaust of the canister and try to blow it out. Yet a third possibility is to reverse the hose on the suction side and **** through the hose backwards.
Best regards, --W/D--
Aug 08, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Best of Luck
Jun 04, 2009 | Easy Flo EF1400 Central System Vacuum
Little suction in craftsman canister style carpet/floor cleaner
you might have a leak on the suction side...perhaps the housing is not properly secured, or there is a **** in the black plastic hose.
Sep 10, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Go Ahead. Use Us.
Jun 30, 2008 | Fantom Vacums Lighting Canister Vacuum
Emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Aug 02, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
