Question about Zanussi WJS1197W Front Load All-in-One Washer / Dryer
I am trying to get a user manual for a Zanussi Jetsystem 1600 XC6 the model number is WJD 1667W. Please could you advise how I can get hold of a copy or if I can download this on line.
SOURCE: zanussi jetsystem 1600
HI,
Just had the same problem with a Zanussi JetSystem 1000 - fabric cconditioner was remaining in the drawer - and my wife reckoned the clothes didn't smell as nice!!!
I fixed this in about an hour and a half without any real problem - might be nice having someone bringing in the odd cuppa whilst you're working!!!
Firstly make sure the dispenser drawer is CLEAN - I spent a good half hour brushing it under running water in the sink - make sure it's 'really' clean and that there are no blockages. Remeber there's a small part over where the conditioner goes (has MAX on it) that lifts up. Also thoroughly clean the part of the machine where it slides into, this is not as easy - I found an old fashioned scrubbing brush and plenty of water worked well. Don't worry if dirty water goes into the machine - you'll be running it empty after the repair to check that all is ok...
Next step is to remove the top by unscrewing a couple of small bolts at the back, right at the top, one in each corner, just behind the top panel and slide the panel backwards and away from the machine.
Make sure the machine is NOT connected to the mains - remove the plug to be sure. Slowly turn the programming knob and you should see a plastic lever being moved as the programmer goes 'round. This plastic lever is near the front of the machine and angles 'round over the dispenser tray assembly. This turns a turbine-like plastic wheel (you can't see it as it's over the top of the dispenser tray, near the back). You'll know you're looking at the right thing as there are a, b, c, d markings around the outside and the wheel (from the top it looks like a plastic disc) has a little pointer. This moves 'round between the various letters as the programmer goes 'round. In my machine it sits half way between a and b when the machine is off. It is this that routes the water to the various compartments within the dispenser tray and if I remeember rightly it MUST point to 'd' to send water to the fabric conditioner tray. Turn the programmer knob slowly to check that this happens.
Whilst I was at it I removed this assembly and thoroughly cleaned it - it's a bit tricky but can be tackled by anyone with a bit of patience. Remove the plastic clip that holdds the plastic arm to the disc - be very careful as the wheel will partly drop into the dispenser tray - that's not a problem as you'll remove it later BUT there's a small spring underneath it that in my case flew through the air and took me ssome time to find. Try and see how this spring is fitted 'before' you strip this assembly, it's placed so that the wheel is held lightly anticlockwise. There's a bit of looseness in this assembly and if the spring was not there (or had come loose) the wheel might not come 'round enough to direct water into the fabric conditioner tray. When you have the clip and spring safely put away you can move the arm - note that it has a fork shape which connects it to the wheel. Let the wheel drop into the tray - you may have to turn it 'round a bit from inside but it should drop completely and you can give it a good clean under the tap. BEFORE you remove the wheel look carefully at it's top - the bit that you removed the clip from so you'll remember how to position it when you reassemble.
Putting the above bits back together is a straight reversal - ideally you need about 4 or 5 hands but you 'can' manage it with two - it's a bit fiddly but not difficult.
Incidentally the problem with my machine was that the spring had moved - and was just sitting loosely doing nothing - instead of holding the wheel in the most anticlockwise position - bearing in mind where the programmer had set the linkage at any given time.
Reading thru this quickly it all sounds a bit complicated but looking at the machine it 'should' all make sense.
We've just done a wash - and at the end I checked - and the fabric conditioner tray is empty!!!
Mail me if you get lucky!
disgruntleddell@yahoodotcodotuk
Posted on Sep 21, 2008
SOURCE: ZANUSSI WASHING MACHINE
seems to be a problem with the filter. was with mine.. one thing i always forget to clean it regularly.
Be careful when open the little hatch thingie , there will be water coming out . so prepare with a bakingtray and kitchen towels. and open it SLOWLY!!! so the water doesnt totally soak the floor.
then clean clogged up filter. at least that solved the problem in my case, hope it works
Posted on Dec 29, 2007
  • 74 Answers
SOURCE: Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Posted on Feb 17, 2008
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
SOURCE: How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
Posted on May 19, 2009
Zanussi jetsystem 1600
Get all of your towels. That little square on the bottom there. Open it with a flat head screw driver. There's going to be a trap there. Unscrew the lint trap by twisting the filter counter clock wise. Be warned, this releases the water. Check to make sure that trap isn't completely clogged with stuff. Put the trap back in tight and properly make sure the tub holds water before putting the square plate back on. ; ) . Voila
Apr 27, 2013 | Washing Machines
Technician sent by Mastercare changed 4 temp sensors and a water valve on our Zanussi WJD 1667W washer dryer to try to get rid of problem of tumble dryer shrinking clothes. After he left found that tumble...
most likely it is a wire that has pulled loose while it was going into its spin fucntion or its agitate seeing how it did work at first and then failed after an amount of time technicians these days are always in a rush to get to the next job. He should stay and watch the machine complete all the cycles after he is done repairing.if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
p.s make sure there is no charge by his company for him returning to complete the job you have already paid for
Mar 17, 2011 | Zanussi WJD1667W Front Load Washer / Dryer
Zanussi jetsystem turbodry 1600 wjs1665 w is not heating the water
More than likely the heater element has failed.
This is located at the rear of the washer drum.
It means removing the rear half of the cabinet to access it.
Mar 29, 2010 | Zanussi ZWF1430W Front Load Washer
I NEED A USER MANUAL FOR MY ZANUSSI AQUACYCLE 1200 XC6 WASHING MACHINE FX1265W TO ENABLE ME TO IDENTIFY THE DIFFERENT PROGRAMME SYMBOLS THE PRODUCT NO.IS 91479270300 TYPE F6857648 CAN YOU HELP
You can download a user manual from here:
http://safemanuals.com/user-guide-instructions-owner-manual/ZANUSSI/FX1265W-_E
Kind regards,
Ian
Nov 29, 2009 | Zanussi Washing Machines
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
Zanussi WJS1197W Front Load All-in-One Washer / Dryer Logo
361 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
