Question about Kenmore Side by Side Refrigerator
Kenmore fridge leaks water on floor and then stops cooling. Tech said it needed heater/defroster and would cost $500. Does this sound right.
  • 132 Answers
Ah no. If the fridge was not defrosting then water would not be leaking out.
It sounds like the defrost timer is not completing it's cycle. You may need a new defrost timer.
The cost of a new timer, call out, fitting and testing could be around $375
Posted on Apr 01, 2011
Kenmore freezer is leaking water onto the floor
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 19, 2011 | Kenmore Side by Side Refrigerator
Kenmore fridge leaks water and stops cooling. Tech came out and said it was a heater/defroster unit that would cost $500. Sounds correct?
$500 for a defrost heater replacement? Rip off city ! Don't know for sure what prices are in your area, but around here, that's about 3x what it should be.
Mar 31, 2011 | Kenmore Refrigerators
Water leaking from the bottom of refrigerator into the floor, I have to weep the floor every second day.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Kenmore 74822 / 74824 Top Freezer...
Kenmore top mount refrigerator freezer, ices up, water leaks through fridge vents, then freezes on fridge shelf. Automatic defrost issue?
sounds like could be defrost timer or heater issue...when in doubt contact a pro
if you need a part try www.appliancepartssolutions.com
Jan 16, 2010 | Kenmore Refrigerators
Refrigerator stopped cooling & freezing
2 possibilities here, the defrost system has mailfunctioned, this is realitevitaly cheap to fix, 2 parts are most likely at fualt, The defrost timer or the defrost eliment, failing it is either of the previously mentioned you may have had a brazed joint failure and the gas has leaked, with domestic fridges if a gas leak has occured it is usualy cheaper to replace the entire unit.
Should it be a part of the defrost system how ever then it is best to have it repaired, to find out which you will need a fridge tech to come and see it in person!
Aug 28, 2009 | Kenmore Refrigerators
Water on floor at front right of refrigerator
Yep got a wood floor 1/2 way up do to water leak.
First lets decide where your leak actually is.
Fact: If the drain pan is dry does not mean that the water being disposed of during defrost is not getting to the pan, It could also mean that the water that is reaching the pan is being evaporated like it is suppose to be. So we have to find your source of the water first then decide on what is causing it.
Areas to consider:
1"Inside" coming out the front from under the door? This is most likely a stopped up drain pan. A cold area that is not suppose to be cold like when you have a freezer coil that is suppose to be defrosting and is not... See below for a more complete ideas list of things to check under Possibility.
2"Outside not underneath" The corner of the door also could indicate (if you have water in the door) a worn out water line or a kink in it that has finally started to leak. Turn off the water to the refrigerator for 2 or 3 days and see if the problem disappears. If so you know whats going on and can approach it from the door area.
3"Outside underneath" The corner could also be where the water is running to from someplace under the fridge. The drain pan drain line is the most common. Inspect it and repair as needed, maybe its just not over the pan. A new house keeper not acquainted with this box may have knocked it out during vacuuming just put it back over the pan. IF The sealed system has had refrigerant added it could be from an over charge and frost on the suction line defrosting during a shutdown.
Possibility's:
1 There is a drain that carries away the water under the cooling coils. These coils are in the freezer section.
2 The damper going to the crisper( s) is open too far allowing cold air to cause condensate on the fridge wall or bottom.
3 The freezer section is not defrosting and there is a spot where the ice buildup is allowing conductive cooling into the refrigerator section and therefore is allowing condensation on the refrigerator wall or ceiling.
4 The refg section has a heater (possibly not positive) in the area of the door frame, or it may have a "power saver" switch. This switch and the heater (if it has a heater it may not have a switch) are designed to stop condensation on the refridg while running. I fit is placed in the "power save" mode it turns off the heater. But, if you live in extream humidity (Great lakes east side or Gulf coats Houstion...) the humid air will condensate water out and it will collect and settle on the floor.
5 Door gaskets are not sealing especially on the bottom of the door. This allows warmer air into the fridge section and it is condensation on floor under the crisper.
If you check all of these items and still cant find it please post back and tell me what you did find. So I can help you more. Please rate me as much as possible as Im trying to keep my average up and do the things that will actually educate and help people.
THANK you for using fixya and good luck..
Mar 22, 2009 | Frigidaire FRS26R4A Side by Side...
Kenmore side by side Refrigirator
Sounds like you have a defrost problem. The timer could be playing up and taking too long to defrost, which causes the evaporator to ice up, hence no cold air to the fridge and the water line freezes up, hence no water dispensed. When the timer does eventually defrost the fridge then everything returns to normal. This could also be caused by a faulty defrost terminator or bad connection on the defrost element.
Sep 15, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore Side by Side Refrigerator Logo
104 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
