Question about Nokia N900 Smartphone
After I dial a phone number the display light goes out and so I am unable to continue dialling extension numbers, if necessary. The power saver switch is "off". I have to open and close the keyboard slider to get a keyboard display. Thanks in advance for your assistance.
  • anaromero200 Mar 31, 2011
    Thank you, Diodeic.
    Unfortunately, I will only know whether the proposed solutions work after going to a phone repair store where a technician can check the "flex" and then the "screen" if necessary.
    Will let you know if the problem is solved after these checks have been made.
    Genius:
  • 1,622 Answers
Hi, what causes the display light to go off is the flex of the cell phone.
he flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Posted on Mar 31, 2011
  • SANYADE  OMOTOLA
    SANYADE OMOTOLA Mar 31, 2011
    ok ,no problem about that,just keep me posted.
Our KX-T7630 seems to delay a few days before sending individual message bank messages through to individual handsets. How can this be? I arrive at the Office, take 2 or 3 messages off, the phone...
Hi
When your red light is on with the handest down presss the message key. this will tell you where the message has come from. I expect you will see that an internal extension has dialled you by mistake. It is a message waiting function on the system for user to call back on. Nothing to worry about. To clear the light you have 2 options either press the clear button on the display for each message or dial *700(then your extension number)
Speak Soon
Phil
Oct 28, 2012 | Panasonic KX-T7630 Corded Phone
How do I set my speed dial numbers?
Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
Carl
Jul 12, 2011 | Lucent PARTNER18 Corded Phone
HOW TO PROGRAM ONE TOUCH DIALLING FOR KX-T7730 WITH CO BUTTONS ONLY ON THE RIGHT?
So that we're on the same page, a 7730 has PF bottons on the right and "CO" buttons on the left. If you have a different phone, like a TA-308xx or a Euro phone that isn't offered in the U.S., then it may only have a single row of buttons.
Programming is the same. If the button is a CO button (with a light), then your one touch requres a "2" in front of it to speed dial a nunber and a "9" or outside line access code to dial an outside number. So, to call 212-555-1212 you press PROGRAM the CO button, 292125551212 STORE. An inside number is stored under the CO button with a "1" plus the extension number.
A PF button already has the assumed "2", so you would just dial 92125551212 in the example above.
Carl
Dec 13, 2009 | Panasonic KX-T7730 Corded Phone
International dialling codes
After dialing 011, the 3 digit code for Lithuania is 370. Dialing 011+370+(phone number) should work. Add 2 0's to the370 if a 5 digit couintry code is necessary. Below is a link to help with interational calling. All the best!
Greg
http://www.q7c.com/travel/telephone.htm
Jun 17, 2009 | Office Equipment & Supplies
Can you tell me how to get out of SP-PHONE which has a red light
Under my Intercom light I have a green light (7731,7735). I'm not sure why yours is red, but here are a couple of things to try.
Press "1" on the keypad without picking up the handset. That turns off Background music and the display will say BGM On or Off.
Press Intercom or pick up the handset and dial 790. That's the extension reset code.
If neither one of these work, post back with the model number of the phone system cabinet the phones are plugged into. It's probably a Panasonic TA-624/824 but there's a chance yours is different.
Carl
Mar 02, 2009 | Panasonic KX-T7730 Corded Phone
Where is the redial button on my KX-A144ES
you need to press the interlocking circles button on the handset (in the centre at the top) to show the last number dialled (incidentally, you can now press the down arrow to scroll through previous dialled numbers).
When you get to the one you want, simply press the green handset button to dial the number displayed.
That's last number re-dial in 2 steps (there is no single click solution)
Feb 06, 2009 | BellSouth GH5816 Cordless Phone
Call Park Issues..
Well to place a call on Park:
-> you should answer the call -or- be on a call
-> press FEATURE 7 4
-> then look at the display as it will give you a park number
Anyone can pick up a phone now, then dial that park number which you've seen - to answer the call.
To Transfer:
-> press FEATURE 7 0
-> then dial the extension you want to transfer to...
Now you can either stay on the line to tell the person who you are transferring and then hang up the phone -or- just hang up after dialling the extension to complete the transfer.
Jan 26, 2009 | NorStar M7310 Corded Phone
Nokia 1100 Speed dialling
Press Menu, select Contacts and Speed dials. Select the key you want,
( to ) and press Assign. Select whether you want to assign to call or to
SMS. Select the name you want and press Select.
After the phone number has been assigned to a number key, you can speed dial
the number in the following ways:
• Press the corresponding number key and then press Call, or
• If Speed dialling is set to "on", press and hold the corresponding number key
until the call is started
Nov 30, 2008 | Nokia 1100
Unable to get call log details
I'm a user of Sony Ericsson K800i, unable to get call display, ie., missed call list, dialled call list, number display etc.,
Aug 25, 2008 | Sony Ericsson K800i Cellular Phone
Nokia N900  Smartphone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
