Question about Dishwashers
Will not run. Unplugged and replugged. Only light that will come on when touched is Heavy Cycle light. But dishwasher will not turn on
  • 4 more comments
  • Mike McMichen Mar 31, 2011
    No such button on my dishwasher
    no such button on model KUDK0 1TKBL1
    now rinse only is blinking. no other button works
    Thanks, but only buttons I have are in two sections:
    Cycle: Heavy - Normal - Light - Rinse Only
    Options: Hi Temp Scrub - Energy Saving Dry - Delay hours
    Does this help?
    OK, I see. Rinse only is still blinking and no response from reset sequence. So I guess I will order a computer control board. Thanks.
    One last question... because I am only getting lights and no running of the dishwasher, does this take away the thermal fuse as a possible problem? I read where the thermal fuse would possibly be a problem if the dishwasher was completely dead...
  • 4,323 Answers
Hi
Press and hold the AIR DRY/HEATED DRY for 15 seconds to reset the control, if the issue returns then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 31, 2011
  • 4 more comments
  • Daniel Scott
    Daniel Scott Mar 31, 2011
    Press RINSE ONLY
  • Daniel Scott
    NO HEAT DRY
  • Daniel Scott
    mso-ansi-language:EN-IN;mso-fareast-language:EN-US;mso-bidi-language:AR-SA">To
    resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat
    Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub,
    energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run
    for 2-3 minutes and then you press the Cancel/Drain button and allow it to
    completely drain and reset. If this doesn't work then it's an issue with the CONTROL BOARD that should be replaced.
  • Daniel Scott
    Yes already told you the reset sequence....please read my previous comment :)
  • Daniel Scott
    Alright
  • Daniel Scott
    You can test the thermal fuse with a voltmeter for continuity before replacing the control board.
GE GDWT160R dishwasher.
Some type of dirt or dust got in your panel, now the contacts don't touch. Not a diy job.
Jul 27, 2017 | GE GDWT160R Dishwasher
Unit will not run. cannot enter diagnostic mode.
i would say that you have a bad touch panel..99 percent positive
May 10, 2010 | Dishwashers
Control panel lights but won't start
the front control panel fries out.. We had to have ours replaced after 7 months ... after that was replaced it only lasted 2 months... WE ARE VERY disappointed and will be calling once again tomorrow. The dishwasher is not even a year old yet!
Aug 16, 2009 | Maytag MDC4650AW Built-in Dishwasher
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Asko D1796F1 builtin...lights are on but no one is home
Our Asko D1796 dishwasher has the lights on the panel working as usual but you can't select a cycle and it won't turn on. We unplugged the pipe. If we turn it off and wait for 12+ hours we have gotten it to work twice.
Mar 02, 2008 | Asko D1796FI Built-in Dishwasher
Touch Temperature Controls not working
Unplugging and replugging worked great! (We left it unplugged for about one minute. The motor started up almost instantly but we still had no numbers on display. I discovered that after replugging, you need to touch one of the up or down arrows for the display to reappear. What a lifesaver this was! Thanks so much.
Apr 09, 2006 | Amana ABB1927DE Bottom Freezer...
Start Cycle won't start, just flashes
first of all, with any problem, always try to reset it, unplug it for 20-30 mins or so and replug. it sounds to me like The motor is probably froze up. Very common if they sit for any length of time. Easy to fix too. Just get underneath it and look for the blades on the motor shaft. Give them a turn. BE CAREFUL NOT TO TOUCH ANY WIRES though. Unplug it first if you can. good luck.
Mar 27, 2006 | Kenmore 24 in. 16299 Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
Owen Barnes
