Question about Honeywell (formerly Hand Held ProductsHHP) 4800 Document Reader USB Kit Imager Integrated Stand Handheld Barcode Scanner
I have Windows 7 x64. I have a Honeywell 4800p USB barcode scanner. I downloaded and installed the driver which created a com5 serial interface to the USB. The device appears in device manager. I downloaded and installed the EzConfig program. When I run the program it displays a dialog window which states that it cannot connect to the device. Can you give me step by step instructions on getting the scanner connected to my computer and working?
2 Suggested Answers
  • 34 Answers
SOURCE: I have a Honeywell 3800g Barcode Scanner with a
Most barcode scanners will not use a standard mini-din to USB adapter. You need to replace the cable with a USB cable designed for that bar scanner. Here is a Google shopping result for the cable you need. Good luck!
http://www.google.com/products/catalog?q=honeywell+3800g+usb+cable&hl=en&safe=off&prmd=ivns&biw=1419&bih=695&bav=on.2,or.&wrapid=tlif129971812876510&um=1&ie=UTF-8&cid=1100600390771774037&sa=X&ei=_B94TdetEI6NrQG6p5nuCQ&ved=0CF0Q8wIwAA#
Posted on Mar 10, 2011
4600g
Basically you don't need any driver for USB interface,but will take longer time to auto install the driver on certain version of Windows 7.
Jan 08, 2014 | Honeywell 4600g Wired Wand Barcode Scanner
I would like to use the honeywell 3800g14-usbkite scanner on widows 7. The user guide says that as soon as the scanner is plugged into the usb, the scanner will beep, despite downloading official drivers...
Go to Control Panel. Open Device and Printers. Do you see a picture of your scanner? If not, run the Windows Troubleshooter and have it detect new devices. Iff you do see a picture, right click on the picture and have it update drivers
Nov 01, 2017 | Honeywell 3800g Barcode Scanner PN...
Hello Is there any driver for use this scanner with usb port?. Thanks.
Please go the Honeywell site listed below (as they are the parent company of Metrologic).
The link should take you directly to the software downloads pages for the Metrologic MS3580. The software you are looking for is Honeywell Scanning and Mobility USB Serial Driver...it is 4mb in size.
Please follow directions carefully during installation as these scanners are a little finicky on driver installation.
Please click HERE for the link to the website and then click "software" to be taken to the drivers page.
Hope this helps.
Thanks,
May 09, 2011 | Metrologic Instruments Metrologic MS3580...
I have a Honeywell 3800g tethered barcode reader that has been working fine on the same computer for approximately 3 weeks. It has been used to scan patient ID bar codes and drug NDC numbers in our...
It's a USB scanner. Maybe you accidentally scanned some rogue barcode that changed the default symbology to something that you can't use in Meditech. I would start troubleshooting basically with this. On the PC where it no longer reads into your Meditech software, try to remove and re-insert the USB cable on both ends - scanner and USB port. Next, ensure that the scanner's driver is set to use this HID (human interface device) as a keyboard emulation device. Next, get (or download and print) the manual for the device, because it has barcodes for changing scanning settings, symbologies, etc. Scan the barcode that says "Reset to default settings", then try scanning again. At this point, if you still cannot get a reading in the Meditech software, try to specify the correct symbology for your medication barcodes. If you still have issues, try a different USB port on the same PC. If still issues, try a different PC. If it works on Meditech on another PC, perhaps you need to update your Meditech version on the bad PC to match the version that works. If all else fails, exchange it for another one; perhaps it truly is defective. I hope you can get up and scanning again!
Edit: I just realized this scanner has more cables than just USB. Are you using a wedge? If so, what kind (PS/2, RS232 (serial) interface, etc.)? There is different troubleshooting for PS/2 and RS232.
Mar 24, 2017 | Honeywell Office Equipment & Supplies
Scanner not found on PC
you install SOFTWEDGE! then see virtual port comm5. regards Roberto (barcode.discount skype)
Nov 19, 2008 | Symbol LS9208 Hands Free Barcode Scanner
Fail to configure metrologic usb barcode scanner to use virtual RS232 port interface
First check the com port speed of computer port which you connected scanner .Com port speed should be 9600.
To change com port speed in computer go to computer/properties/device manager.
Select the ports eg com1 .Right click communication port go to properties and select port settings Bits per second should be 9600.
Serial scanner can not be test in word or note pad.you can download the RS232 software from below link and test the scanner
http://www.lookrs232.com/
Oct 30, 2008 | Metrologic Instruments MK9540...
CIPHERLAB 1000 (serial ) Driver for WinXP
you dont`t have a driver for serial comm.open hyper terminal on com port where is the scaner.read a code and you wilkl see the numbers on the screen.If you want to work with some windows programs change that barcode for usb or ps/2 variant.
Jan 15, 2008 | CIPHERLAB 1000 Handheld Barcode Scanner
Honeywell (formerly Hand Held ProductsHHP) 4800 Document Reader USB Kit Imager Integrated Stand Handheld Barcode Scanner Logo
334 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
