SOURCE: hotpoint aquarius 1000 deluxe
Try the "spin only" button to take the water out of your machine. If this does not work, take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
Plug off the wall, & check your outlet filter first.
Posted on Nov 26, 2007
SOURCE: Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Posted on Mar 10, 2009
SOURCE: Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
Posted on May 17, 2009
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
SOURCE: brand new whirlpool, front loaded washer, during
Remove the shipping bolts in the rear of the machine.
Posted on Nov 08, 2009
Jun 15, 2012 | Hotpoint Washing Machines
When
my washer did that, I found that the shocks that hold the tub were
bad...
Check out this tip I wrote about the noise and
vibration that front load washers can make..
Washer Problems
Washer
noise
when spinning
heatman101
Feb 21, 2011 | Hotpoint Aquarius WF220 Front Load Washer
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Feb 11, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Jan 23, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Jan 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Oct 22, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
158 people viewed this question
