Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover floormate h3000 w/spinbrush will not dispense the cleaning solution how can i fix
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
The hot glue trick will work; but what you probably need to do is gently push down on the black pin from inside the tank. This will lower the solution release mechanism and the solution will dispense. I found this solution on this website and it took 10 seconds and worked well.
Posted on May 01, 2011
  • Alan
    Alan Nov 19, 2014
    I don't know why this worked but it did. Thanks!
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
My hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
May 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate h3000 not dispensing cleaning solution after sitting for extended time
check the seat valve on the bottom of the solution tank. should move upward freely. could be stuck if sitting for long period of time
Nov 03, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Floormate Spinbrush
Not sure if this will help but these machines are ment to be used in one direction not back and forth like a vacuum cleaner. You should start in one spot and pull towards you slowly with the trigger depressed it is designed to spray scrub and pick up the solution all in one pass by going back and forth you are pushing the rubber across dry parts of the floor and it will make noises. For any parts or cleaning solution you may need visit www.stevessewandvac.com
Jul 27, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate won't dispense clean solution
The tank sits on what is called a reservior asm, that may have gone bad. Does the water flow out of the tank when you push in the valve at the bottom?
May 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate problem
I found a solution posted by someone elsewhere on this website. Try doing a search for Hoover Floormate H3000... The posted solution is as follows:
Remove the liquid dispenser and set it aside. Locate the plastic "plunger" piece in the machine that is surrounded by a black rubber circle (the one on my machine is blue/grey in color...). Place a small drop of hot glue on top of this plastic "plunger" piece and let it dry. Replace the liquid dispenser and test the machine. This solved my problem and my machine dispenses liquid properly again!
I really appreciate the original poster who posted this simple solution.
Aug 16, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
534 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
