Question about Delta & Lockwood& Tub & Shower Faucet
Water comes out both spout and showe head when temperqture control is adjusted
    Problem Solver:
  • 9 Answers
Something is blocking the flow thru the tub spout. Make sure the dirverter moves properly. It mat be stuck partialy closed.
If that does not work take the tub spout off and see if you still have the problem. If that fixes it get a new tub spout.
Posted on Apr 01, 2011
Water leaking not just comming out of spout
Sounds like your water outlet is clogged. Open the head and push up the cup holder to remove. When out, clean out the tube at the bottom of the holder with a paper clip or something similar (I use a cake tester - long skinny metal rod. This will clean out any clogs in the output path. Also remove the bottom part of the cup holder and clean it too. Put back together and place back in brew head the way it came out. (Caution - some models you have to twist the cup holder to remove, and some it just comes straight out). There are many you-tube videos that will show you this also.
Mar 27, 2014 | Keurig Vue Brewing System
Hot water is very slow coming out spout. Cold water comes out fine with good pressure..
the anti scald is adjusted too low. its located under/behind the handle. it usually has am allen wrench head. remove the handle and adjust it all the all the way to hot that should fix it. on some models you can remove the entire thing,but on some that will cause the handle turn 360deg because in some models its also the stopping point of the handle. hope this helps
Dec 11, 2012 | Jacuzzi Home
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Water comes out spout and shower head at same time
Hello gruber d, you need a new spout. When a spout is working properly you raise the knob on top and it slides a baffle over the outlet at the spout. Once the water is blocked from flowing out of the spout it forces water up and out of the shower head.
You may also remove the spout and see if you can get a closer look and see if you can make some kind of adjustment to it.
Removing the spout;
1. Put a cloth around the spout to protect the finish.
2. Adjust a pipe wrench to fit over the spout and the cloth.
3. Turn the spout counter-clockwise to loosen.
My goal was to provide timely and accurate information. If this has been helpful to you, please
consider taking a second to click on the, " this was helpful ", button.
Than you!
Jan 13, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
When lever on tub spout is pulled up for shower use some hot water still comes out of the tub spout...reducing water pressure and temperature of water coming out of the shower head... Tub spout does NOT...
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
I turn on the spout for my tub and i turn the dial for my shower head to come on and it does, no problem, the shower head shoots water at full force, great water pressure, but there is still water coming...
I would look into the spout being the issue. The spout is a bypass when the shower is on and yours seems to be letting water get through. I would replace the spout..
Apr 27, 2010 | Price Pfister 01-311 Shower Head, Tub...
HELP!!Water from spout and shower head
check to see if the diverter is stuck midway, ( the lever that changes the direction the water flows to). if so may be corroded and sticking each time
Apr 08, 2010 | Home
Water leaks out of shower head during tub use. valve was installed properly
The pipe to the tub spout is either restricted or the valve was placedd too high causing some of the water to come up and out of the shower head instead of it all flowing out of the spout.
Nov 12, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
No shower water
the spout is also the diverter which sends the water up to the shower head. Assumming that the shower head isn't clogged with lime you should be able to solve the problem by removing the spout and taking it to a hardware store or home depot for a replacement. Most spouts just unscrew but some have a set screw which holds em in place. Look for the set screw on the underside of the spout. good luck
Jan 18, 2009 | Price Pfister Ashfield Single Control...
Delta & Lockwood& Tub & Shower Faucet  Logo
210 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
