Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
Turn on the controls for the burner and the indicator light comes on but the burner never gets hot.
  • owcrewe Mar 31, 2011
    so the control that turns on the burner catridge will still light up without supplying power to the burner.
  • 4,323 Answers
Hi
If all of them are not working and the light comes on then it can be because of the infinite switch that is bad and should be replaced unless you are able to find a loose or broken wire inside the oven. Hope you understand all the elements cannot go bad at the same time. Please check these diagrams that will help you in your repair. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 31, 2011
  • 2,382 Answers
Hi, you may have a short in the line that feeds the electricity to the burners. The oven and the stovetop are probably fed through separate electrical wires. The thermostat may also be faulty or the element is probably bad. Unless you know something about electrical wiring, it might not be wise to attempt to fix it on your own.
  • Tunde Autos
    Tunde Autos Mar 31, 2011
    Yes, it's very possible for the control to turn up without supplying power to the burner..
Are there problems with the kenmore 36-in. radiant cooktops 42749 hot surface indicator lights?
Most likely the problem is in the heat control switch.Cannot be repaired you will have to replace it. To make sure, swap it with one of the other burners that do not have the problem. If the problem goes away, you know its the switch.
Aug 08, 2014 | Kenmore 36 in.42741 / 42742 / 42744 /...
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
My GE glass cooktop has a red light that goes on when in use (not theburner indicator light but a general light as soon as you turn one of the knobs. For some reason, today it is dimly on--even though...
I assume you are talking about general pilot light which illuminates when you turn any of the four hotplates on. This light gets its power supply from the hotplate contollers. The controllers generally have a pilot light circuit which links all 4 controllers to the pilot light. I haven't seen this problem before. Either a small amount of power is escaping across the pilot light contacts inside the controller or the pilot light is getting a feedback from another source/fault in the cooktop. The only solution is to dismantle the cooktop and use a voltmeter or similar to trace the fault. Unless you understand how the problem occurs it's probably best to call a repairman.
Feb 11, 2011 | GE Cooktops
On indicator light on my Maytag touch control 500 electric smoothtop range will not turn off, even though all burners are turned off. I also shut the power off but the light still stays on
I can't help you with this if the light will not go off on one burner then replace that switch . but if you turn the power off and the light still is on. the unit is getting power from another unknowen source . mm
Jul 08, 2010 | Maytag MEC5430BDS Electric Cooktop
Hot burner indicator light won't shut off
the switch for the bottom right burner is bad but doent not affect the cooking, just the light
Nov 26, 2008 | GE 30 in.JP950 Electric Cooktop
Fixing Jenn-Air Custom Control
Sure, I meant to get a copy of the schematic last night so that I could send it to you with the changes. I'll get it tonight and send it to you along with the info I have now. The only thing that will be different is that you won't have independent controls of the dual element burner. For me that was fine cause my wife and I never use just the smaller burner but rather always both. The part #1009577 from repair clinic.com is an infinite switch which is already being used in the cook top for the largest burner or if not (cause I actually didn't look) for sure it is used in the JEC9536, just the wider model. This part is rated from 8.9 - 11.0 amps or 2,640 watts, when you hook the two burners together I believe it adds up to 3,000 watts so the infinite switch (the biggest I could locate) is slightly under sized. However, I felt most things especially electrical, are over engineered for safety any ways. When you remove the circuit board you will have to drill out the two slots where the two mounting screws will secure the new switch, or you can do what I did and stick a screw driver in the slots and stretch them slightly (very easy to do). You'll need to find two screws that fit the new switch for mounting ( not too long, if your not sure take one off one of the other infinite switches and match it up). I'll have to get back with you on the wiring, it is rather simple though, most of the connections are the same as the other infinite switches. The grainger.com part number 2FBT6 is just a snap action thermal switch that will replace the thermal sensor that went to the circuit board to light up the hot surface indicator. I tried to use the existing sensor but the hot surface indicator lamp stays lit, so I figured that the sensor was probably a 0-10volt or 4-20mAmp switch that the circuit board monitored and turned on the hot surface indicator accordingly. That is a simple hook up also, however, I have not installed that yet cause I did not find out about the thermal sensor not working for the hot surface indicator until after I put in the infinite switch. Tonight I will install it and let you know what wires go where along with a marked up schematic, maybe even photos if you would like.
Sep 11, 2008 | Jenn-Air 35 in. JEC9536ADS Electric...
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Remove ceramic cooktop
grouch, kill the power to the cooktop. You are going to have to remove the mounting brackets from undernieth and push the cooktop up. After it's up from it's installation position remove the side and back screws holding the top to the botom. Remove the burner knobs and it should come apart. Sounds like you have a bad burner switch. Catriver..post back
Feb 26, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
64 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
