Question about Cameras
Hey mate, says "system error
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 31, 2011
I'm hearing a high frequency electrical "whirring"
COuld be a grounding issue. Place a ground plug on your computer where it plugs into the wall outlet. You can get these at almost any store for about a $1.
Otherwise, you might try using a battery backup system.
Mar 21, 2011 | Sony MDR-7506 Professional Headphones
Tascam dp-01fx system 80 error It says " No CD
hey mate i got no solution for yah but if yah work it out e mail me man i got the same problem
da_monk_bomberman@hotmail.com
if i can get some info on it ill contact yah ok
Dec 08, 2010 | Tascam DP01FX All-In-One Recording Package...
Nikkor 70-300 f/4-5.6g lenses will ont auto focus on my D70
The focus motor gear assembly likely has a damaged gear. It will need parts replaced.
May 20, 2009 | Nikon 70-300/4-5.6 G AFD Nikkor Zoom Lens
Olympus SP-570UZ-zoom error
Had 570UZ for 2 weeks and "ZOOM ERROR" occured. Seemed hopeless. Changed batteries several times, bought new Alkaline.
No change. Finally decided that it is probably a connector problem.
Turned Camera Off. Held Camera by the lense barrel. Held palm of other hand and thrust the back of the camera ( LCD side) into the
other hand. The idea being to jostle the camera contents without cracking the LCD. Did this a couple of times, turned camera on and it works fine. At least for this evening. At least for now it seems like a classic component connector problem somewhere inside the camera.
Oct 30, 2008 | Olympus SP-570UZ Digital Camera
Zoom error
Knocking the bottom of the lens end of the camera 3 times on a wood table, medium gentle, fixed a zoom error (where it would not focus in zoom)
The camera had been dropped whilst skiing holiday and this method fixed it. Very Happy!.
Nov 19, 2007 | Fuji FinePix Z2 Digital Camera
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
Error message E25
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix you problem. In any case it could not make it worse Good luck!
Oct 09, 2006 | Canon PowerShot A100 Digital Camera
Cameras Logo
24 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
