Question about Microsoft Xbox 360 Elite Console
Hey im having issues ive had before but fixed easily i just cant remember how to do it. I connect my PS3 through hdmi on my dell W3201c tv, however, now it is saying OUT OF RANGE CANT DISPLAY THIS VIDEO MODE. CHANGE COMPUTOR DISPLAY INPUT TO 1024X768@ 60 Hz. I need help, i just dont know how to change the resolution on my tv through the menu or on the remote. Any one??
    Guru:
  • 592 Answers
Have you tried to reset the PS3's video manually. To do this you turn the unit off at the power supply. Turn it on. Press and hold the power button. You should after a lil time hear a series of beeps. Soon the system shoudl turn off. Turn it on with one touch and it should reset the video for detection mode and then select the monitor by itself.
Posted on Mar 31, 2011
My dell w3201c tv displays "no video signal" when i power it on
Coaxial cable does not carry video signals but rather rf-signals
To use coax you will have to tune like you are searching for a signal from your aerial..
If you prefer to use video then you will have to use a video cable either rca or hdmi. you can then choose video or hdmi from the remote
Len
Sep 12, 2014 | Dell 221-9703 W3201C 32 INCH LCD TV...
My emerson tv say device control inactive
John, I've ran into this issue a couple of times myself. In most cases, there are easy fixes to the issue. #1, Does your TV have multiple HDMI inputs? They may be labeled HDMI1, or HDMI2, etc. I know this sounds strange, but many people don't realize that the signal source is important. #2, Connect the cord, from another device that you know works(laptop-monitor) to eliminate the possibility that your HDMI cord is bad. #3, (Probably most common) The PS3 is not the most stable platform when using the HDMI cord. Remember that the PS3 was one of the "pioneering" platforms using the HDMI connection.As such, the "auto-detect" feature is sometimes confused when switching between RCA inputs, and HDMI input. (Happens every time actually) To fix this, try a video reset on your PS3 system. It's fast, easy, and doesn't effect anything except the video/audio settings. I'll put in a link to get you started in that direction. It is the same with all models of PS3. Good luck! ^^
How To Reset PS3 Video Settings PS3
May 06, 2013 | Sony Playstation 3 (PS3) Console
Hi, i have a DAV-DZ330/DZ730 and i cant get sound from the tv/sky. TV is a bravia KDL 40NX503. Its HDMI connected and ive been through the sync process and made sure the hdmi settings are ON on the amp. No...
i had the same problem with my dz330. simply attach you sky box via scart to the back of your sony box and hey presto you should have sound when selecting tv mode from the sony remote
Aug 14, 2010 | Sony DAV-DZ100 System
Im trying to get my ps3 to connect with another tv
turn off ps3 till the red light is on the machine then you need to hold down power button to turn on until you hear a beep.
make sure a hdmi cable is not connected at back of ps3.
Oct 27, 2009 | Sony Playstation 3 (PS3) Console
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Jan 03, 2009 | Microsoft Xbox 360 Elite Console
HDMI Monster cables
I had the same issue. I think you have to reset your PS3. I don't remember how I fixed it but I did find the anwser in the PS3 user manual "Trouble Shooting".
Dec 27, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Dell w3000 & PS3
This may not be DVI issue.
I connected DVD player HDMI ----> DVI ( Dell W3000) LCD TV.
Later I found that Dell TV version of DVI does not support HDCP protocol ( High Definition Content Protection protocol). So I could not play HDMI to DVI movies from my DVD player instead I use Y Pb Pr -- this works ok.
Hope this helps... I am not use PS3 enforces HDCP - I assume Sony linked with Sony Pictures would enforce HDCP on HDMI cable.
Dec 27, 2007 | Dell W3000 30 in. HD-Ready LCD Television
PS3 - HDMI to SD change issues
While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.Good Luck!
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Hdmi settings?
Hey Kris, this might all be about different 1080 settings. Maybe Your consoles work on 1080i and the TV is 1080p.
It more sounds like your receiver has a faulty HDMI jumper, which you wont be able to fix. Here`s what i would do:
If your lcd has two HDMI inputs, use on for each the receiver and the other for the ps3...
2-For how important is to rather connect the ps3 via HDMI, for picture quality. then simply get an HDMI splitter, yes... YOull have to go and switch from receiver to ps3 whenever you want to play BUT it really sims your receiver is not going to cut it.
The pink you see is an incorrect "GAMMA" signal thats only induced by a malfunctioning software or hardware.
Is your receiver from a cable company? Try to get it replaced.
I would start there and if it wont make a difference, go with the splitter. YOu might get one at walmart, Radio Shack or ebay.
Hope it works and please feedback with results.
Good luck!!!
Jean
Dec 05, 2007 | Yamaha HTR-5990 Receiver
Sound quit working
I have the same problem with the same TV (16 months). So far the only option ive came across is just hooking up a surround system to the cable box for the audio.
Aug 17, 2007 | Dell W3201C 32 in. LCD Television
Microsoft Xbox 360 Elite Console Logo
123 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
