Question about Sony PlayStation® 3 (80GB) Console
My PS3will not read the games but will play the movies fine??
  • Ryan J Apr 04, 2011
    Can you provide an error code
  • 4 Answers
First you should back up any important data onto an external hard drive, or transfer your data to another PS3 via the transfer function. Both options are available through the PS3 settings tab of the XMB.
After all the data you wish to keep is safe, then reformat the PS3`s hard drive via the reformat function also found in the PS3 settings tab of the XMB.
Go to settings, system settings, reformat utility, and follow the on screen prompts.
If this is successful then restore the backed up data onto the PS3.
If this doesnt work you may want to consider a Blu-ray cleaning disc such as this:
http://www.maxell-usa.com/index.aspx?id=63;73;606;0&a=info&pid=596
Cheers and good luck.
Posted on Apr 14, 2011
Playstation 3 not playing games but will play blu ray discs
Make sure that your firmware is updated correctly. Also make sure the games are the correct region for the unit you're playing on. You may have an incorrect region setup on the PS3. PS3 games are region locked, either being PAL or NTSC. If the PS3 is set to read PAL (by being set to a region that is PAL, like the UK, Europe, and Japan) it will not read or play an NTSC disc.
Misconfigured or corrupted firmware installations can also cause this problem. Furthermore, pirated games will not play, because they do not have the appropriate security key on the disc.
You can try testing this by creating a new profile on the PS3 and trying to play the games. If you can play them with the new profile, then there is a corruption with the old profile. If you can't play them in the new profile, then it could be the firmware.
Lastly you may have a blown drive. Most PS3 games are dual layer blu ray discs capable of storing large amounts of data. The blu ray drive in the PS3 uses a sequenced dual laser to read the game. If one of the laser emitters has blown, it won't read the game correctly. However, since it doesn't use both emitters to read blu ray movie disks or dvds they'll still play correctly.
Oct 04, 2014 | Sony Playstation 3 (PS3) Console
My ps3 console will not play game discs for some reason! It will play movies just fine but not games HELP!!!!!
The Playstation 3 is a wonderful video game console, however, with heavy usage, the laser does eventually burn out. The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the game will stop reading altogether (even though movies sometimes still work). Eventually movies will stop working and the whole laser will eventually die.
The following website sells PS3 lasers and also performs repairs:
http://store.richspsxparts.com/pl3isnotrega.html
Jun 17, 2011 | Sony Playstation 3 (PS3) Console
When I bought my ps2 did not read any movie but played normally when I bought a new game started and worked fine but the next day I tried to play again but not working any of my games and read to all the...
If I understand correctly, it seems your lens might be eaither dirty or broken. First try to clean it with a cleaning kit, if that doesn't work, take it to a service center to have it repaired.
Mar 09, 2011 | Sony PlayStation 2 (PS2) Console
My ps2 won't read dvd movies. I put them in and nothing happens. even when i click the browse selection. It plays the games just fine, but doesn't seem to read the movies at all.
you need to have a modded ps2 to play pirated movies which are not official copies if you are using an original dvd copy then try keeping a weight say a small mobile charger or a small book on the ps2 if you are using the slim ps2
Jan 30, 2011 | Sony PlayStation 2 (PS2) Console
Ps3 plays DVD and Blueray just fine, but will not play game discs... can't seem to read them. discs are in perfect condition, tried several different discs, no luck.
Some time when that happens the system configuration is wrong reset the configuration to game play on. That should let you play Movies and game.But!, make sure you remove the disk.
Aug 04, 2010 | Sony Playstation 3 (PS3) Console
My sons ps3 will play games fine, but just started where it wouldnt play 1 move reg type not blue ray. then it wouldn play a couple of movies... playing some but not others, now wont play movies, but will...
depending which ps3 you have.
If you have the dual laser model one of the lasers could be damaged or require cleaning.
so the bluray side would work fine, whilst the reg side for reading dvds and cds could be damaged.
it might be worth buying a cd lens cleaner with the brushes and fluid and running it a few times in the ps3 this could work but you might be looking at the laser being replaced.
Hope this helps
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
3.0 Killed my PS3
Sounds like the laser diode burned out. If your under warranty send it in. If not you could buy a replacment and install it yourself.
Sep 11, 2009 | Sony Playstation 3 (PS3) Console
My playstation 2 plays movies but will not read games why?
The 'Eye' that the PS uses to read DVDs/CDs are different, the one that reads cds has gone bad on yours it seems, so you should still be able to play the games that have the dvd logo, if it is still under warranty I reccommend calling sony.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
Umd
None of what any of yall tellin' me is workin i love ma psp!
help me its diein' it wont play its umds thats like the food it needs! Help me! lol!
really though my unds wont play at all everything else is fine but thats the only problem!
Aug 19, 2008 | Sony PlayStation Portable (PSP) Console
Xbox 360 wont play hd movies
Hi you have to buy a HD DVD player add on for your 360 to play HD DVDs if you go to game or gamestation you will get one there very cheap as HD DVDs are no longer released
Jun 27, 2008 | Microsoft Xbox 360 Console
Sony PlayStation® 3 (80GB) Console Logo
77 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
