Question about Apple iPhone Smartphone
My iphone3 switched off and it can not switcth back on
    Sergeant:
  • Apple Expert
  • 302 Answers
Maybe try going to apple site and try troubleshooting
Posted on Apr 12, 2011
How to activate iphone3 without sim card
It is a required part...
iPhone3 is no longer supported by Apple...
Not a real problem if you can find a compatible CARRIER to subscribe from...
But the slot in the side of your iPhone ought to have a SIM card installed...
ELSE... Apple will work with you the accommodate your needs.
Nov 09, 2016 | Cell Phones
Jailbreak iphone3
Google "RedSn0w" for details and instructions there is a group called dev team that can help you
Oct 25, 2012 | Skech Custom Jacket Flip Leather Case For...
Iphone3 is not charging
Yeah, this definitely seems like something you'll need to take the phone to a specialist for. If you have apple care for the device, definitely take it to Apple directly. If you don't have apple care, there should be local technicians that repair Apple devices. I would just do a google search of the local area.
Dec 12, 2011 | Apple iPhone 3G
Hi there, my son managed to get ahold of my iphone3 and due to me having a password on it he has managed to disable my iphone3, due to entering incorrect password a number of times. The password I...
Plug it into iTunes and follow the instructions on how to reset the phone. No need to take it to apple, they will do the same thing. From--Genius Bar Tech
Aug 13, 2011 | Apple iPhone Smartphone
SWITCTHING TRANSISTER C4584 GETS HEATED .BUT NOOPERATION.WHY?
There is a problem with the "tuning" frequency. There are various capacitors that ensure the transistor actually switches and doesn't spend much time turning on or off and causing heat.
I suspect the switching transformer has a diode on its secondary winding that is leaking and upsetting the tuning.
Hope this helps.
Nov 15, 2010 | Haier HTN20R15 TV
Ignition switcth sticks. want to change myself how do i go about doig this or do i let someone else do it?
you have to pull the steering wheel off and unscrew the locking mechanism (looks kind of like a saw blade) and anything on the ignition side of the steering column until you get to it. there should be a small locking pin on the switch just push that in with a safety pin and the switch should come right out. now when you reinstall everything make sure its tight and connected well. the hardest part is getting the steering wheel back on in the same position you pulled it off.
Feb 23, 2010 | 1994 GMC Suburban
4wd light on dash not working, changed switch on shift, bulb in dash and 4x4 computer control behind centre console. Also changed both switches in front axle but still no 4wd. Why?
Dear Fixya,
Solution at hand. I chased the harness to the gearbox. I methodically electrically earth tested each wire-to-switch and visually checked each wire for breaks whilst another kept turning on and off the 4wd switcth on shift. Eventually, at the rear end of the gearbox there is a multi connector of some several wires. One end had a female and the other exposed male pins. On counting the pins I noticed that one pin, on recollection green/red wire had been drawn back into the connector so not making a contact. I therefore, pushed the pin back through so to make a connection. All of the 4wd pneumatics, light on dash and front axles switches now work. That one wire caused total shutdown of the High 4wd system. I assume that during either off-roading or average road use an object, like a branch, fouled the rear connector and dislodged the wire connection.
Thanks for your quick response. Hope the above will help someone in the future.
Kindest regards,
Carl.
Sep 11, 2009 | 1993 Toyota Pickup
When we turn it on and insert a disk nothing happens the screen is blank and nothing comes on but the green and blue lights are on ?
Have you changed Video settings or swapped from a HD TV?
Hold down power button when switcthed on from the back until you here it beep (approx 5 secs) this will reset video settings
Aug 09, 2009 | Sony PlayStation® 3 (80GB) Console
Proton 34 LCD tv
Looks like Power Supply fuse is gone. Replace with recommended rating and type of fuse and try again.
May 18, 2008 | Protron PLTV-37 37 in. LCD Television
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
