Question about Compaq Computers & Internet
Red blinking power light when connected to power.
  • Compaq Master
  • 27,725 Answers
You have not stated what is not working so i have to guess you need an overhaul
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Mar 31, 2011
TV SHUT OFF, HASPOWER, RED BLINKING LIGHT, WON'T TURN BACK ON, WHATS THE PROBLEM ?
If the red light is blinking, then it either does not have a good power connection or its in a diagnostic mode. The red light should be solid not blinking.
Feb 15, 2016 | Televison & Video
Red stand by light blinking continuously black screen
It cannot be reset fully unless it comes on and stays on (the model you have listed here.)
That set should have a blink error code--watch the red power light to see if blinking in a number sequence like 7blinks pause and repeats over and over.
Dec 20, 2012 | Sony KV-36XBR250 TV
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
May 26, 2012 | Sony MHC-RG222 CD Shelf System
The power button has a blinking red light, what does this mean?
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
Jul 04, 2011 | Buck Legendary: The Box for Xbox 360
The power light on my actiontec m1000 blinks green & red and now my computer can't find the modem. What does the blinking lights mean??
hey
red light on modem usually means modem is in bad state
in this case kindly try to do power cycle
way to power cycle
disconnect all the cables and leave the modem for 30-50secs
then try and connect power cable first
then connect the dsl and then ethernet and see if that resolves the problm,
Sep 18, 2009 | Computers & Internet
Protection light just blink on and off
check that your ground wire is connected properly to both your amp and body of vehcile you may need a thicker earth wire
Mar 23, 2009 | Power Acoustik LT-980/2 Car Audio...
Blinking red light
Red Light blinks when the ink cartridge is bad..
to check which one is bad..
take out all cartridges from the printer and clean the copper contact and the inner area of the cartridge slot with a lint-free cloth...
power off the printer and unplug the power cable from the printer..
press & hold the power button on the printer for 60 seconds..
connect the power cable and power on the printer..
insert any ONE cartridge and close the door..
similarly insert other cartridges one by one and close the door and check if the light blinks..
if it blinks ..it means the respective cartridge is bad and replace it..
if u have replaced all the cartridge..it might be possible that the cartridge sensor inside the printer have gone bad..
if this is the case so ..u might service the printer..
but I will suggest to go for a new printer as 7660 is quite an lod printer which hp launched in 2004 or 2005..
even if u have juz bought it ..it will be refurbished one..
Aug 12, 2008 | HP PhotoSmart 7660 InkJet Printer
6 red blinking lights
6 lights according to the service manual is: LOW B ERROR B_12v IS NOT SUPPLIED (GT BOARD)
Check the connections to the boards, and if nothing seems obvious, you may need a repair person to replace this board...
Jul 14, 2008 | Sony KDS-R50XBR1 50" HDTV
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
