Question about Porter Cable Cable 135 PSI, 60 Gal. Oil - Lube Stationary Compressor C7510
Will not build up air perssure over 50 psi. and the motor will run all the time until I shut it off.
  • Porter Cable Master
  • 885 Answers
The motor will run until the pressure switch detects approximately 150psi in the tank. If it never gets to 150psi, it will continue to run. If you are not getting over 50psi in the tank check:
1. that the drain valve on bottom of the tank is fully closed. Don't use a wrench on it but it must be tightly closed by hand.
2. that you don't have any air leaks on the top end of the compressor or on your lines going out of the tank.
If these are OK, your problem lies either in a damaged valve plate or cylinder/piston. You can remove the head and check the condition of both the cylinders and the valve plate. All reeds on the valve plate have to be in good condition with no bends, cracks or warpage from over heating or debris from using the compressor with no air filter. The cylinders should be smooth with no scaring. If a cylinder is damaged you will have to also replace the rings or piston assembly. None of the air compressor companies make an oversized ring set so you can lightly hone cylinders but you cannot have them bored out oversized to correct any damage to the cylinder walls.
Posted on Mar 31, 2011
Dewalt Emglo 55168 motor starts to slow down as pressure builds to about 30 PSI. It really starts to labor. Any thoughts as to what could be causing the motor to strain and slow?
Most likely in tank check valve is leaking or belt is slipping. Belt tension easy to check, should not deflect with thumb pressure. Check valve should not let air escape out of tank. Easy to check. Run compressor till pressure builds to around 50 psi. Then unplug machine from power outlet. Listen for air leaking out of tank. In bad cases, air will actually leak out of intake filter. Replace check valve as needed. Good luck
Oct 26, 2016 | Dewalt Air Tools & Compressors
Hello I have a 20 gallon kobalt model 033204. I just replase pressure switch but does same thing. When I tur on the compressor jus build 50 psi and shuts off.
This usually occurs when the motors internal thermal / amp breaker opens due to overload or weak breaker. Use an amp gauge to test for too much amp draw. If amp draw is normal, then problem could be the in-tank check valve leaking pressure back to the pump overloading the system, or weak capacitor or weak breaker. Bypass the breaker temporarily if the amp draw is normal to test system. Good luck
Oct 31, 2015 | Psi Air Tools & Compressors
I have a 80 gallon 5 hp ingersoll model #2475N5 serial #30T900896. Im using 10-3 wire on 40amp doible pole breaker. as its building air when it hits @50 psi it slows down. if I pull the pop off valve on...
T wo suggestions. 1- check the check valve located in top of the receiver tank by letting the unit pump up to 50 psi. shut it off and loosen the copper tube at the HP cylinder. if no air blows out the check valve is good. If it's bad it will blow until it empties the tank. If the check valve is bad replace it. 2- Tighten the drive belt. If neither corrects the problem remove the guard and rotate the pump by hand. If it's hard to rotate you have a pump problem.
May 08, 2011 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
My compressor will not go over 20 psi i have a craftsman 921 4 gal 125 psi compressor and it will not build past 20 psi i do not know how to get to the pistons and stuff what do i do?
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Mar 01, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 5hp 16gal. 135 max psi. The compressor builds up to about 50 psi. But no more. The compressor continuously runs never shutting off. I can hear no leaks. Also the on/off switch runs in the off...
take the power surply cover off and look down the side on the butten at the contacts, id say it isnot the pressur switch itself, and make sure all bolts are tight and check the reeds
Jun 10, 2010 | Campbell Hausfeld 02-Gallon Air...
Unit builds to 25-30 psi then shuts off. You must
unhook the output line from the pump. run unit for 5 to 10 min. if no problem, check the tank valve at the end of you out put line, it screws into your tank. that valve must shut off at every down stroke of the piston, or air well flow back to the pump. will put an overload on the motor. good luck
Oct 16, 2009 | Campbell Hausfeld Air Tools & Compressors
Air Compressor will not build up over 25 PSI
your max pressure switch is faulty, and shutting off the power early. replace switch, check owners manual for location(should be near power wires)
Jun 14, 2009 | Hitachi Air Tools & Compressors
Mastercraft 2.0 hp air compressor will not build up over 25 psi
sounds like a bad or broken valves in the head. crankcase needs a vent which is sometimes a small hole drilled into the oil fill plug and will normally blow some air out the vent while it runs
Mar 22, 2009 | Air Tools & Compressors
The compressor only reach 50 PSI.
Does the compressor continue to run but not build more pressure? In which case it is an air leak most likely, or does the compressor shut off at 50 PSI? In which case it is mose likely the pressure switch. If it is an air leak you can un-screw the guage and coat with putty or teflon tape and reinstall to clog the leak around the threads..
Jan 26, 2009 | Porter Cable C2002 Wk 150 Psi 6 Gal. Oil...
Porter Cable Cable 135 PSI, 60 Gal. Oil - Lube Stationary Compressor C7510 Logo
225 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
