Question about Car Audio & Video
I have a zapco iforce 1200 protect light comes on and i hear a clicking noise then it turns all the way off
2 Suggested Answers
pnevai
  • 48 Answers
SOURCE: power light
This could be a DC offset condition. Check you manual for what this means. Or other condition. First Disconnect the Subs and try it. If it still goes red then disconnect the RCA's and try it again. If the Led continues to go red after the click then the Amp is hosed. The Click you hear is an internal relay that cuts the subs in after a dely so you do not get the turn on THUMP of the radio at your subs.
Posted on Jul 14, 2007
Clicking noise
take a visual look under the car if anything loose. Any lights coming on? ARE left and right signals ok- sometime they make clicking noise.
Nov 05, 2013 | 2006 Jeep Grand Cherokee
I installed a 400 watt zapco competition amp\ front speakers play ...back woofers don't?
are you sure you didnt wire the amplifier the front and rear to
left/ right?
check your deck settings to see that the rear speaker rca are connected.
check all wires are connected.
push the mono or bridge buttons are off.
provide more info.
Nov 03, 2013 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
How many rms does my amp have.....??????
4-channel, 4 ohms: 4 x 50 Watts
4-channel, 2 ohms: 4 x 90Watts
Stereo, 4 ohms: 2 x 180 Watts
T.H.D. : Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Dimensions: 13"L x 9.9"W x 2.25"H
Zapco I450 Zapco I 450 iForce Series 4 Ch. 360 Watt Amplifier
May 22, 2011 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
I need a manual for a zapco PEQ 9 band (old school) equalizer. can you help me?
i got a wiring paper that comes with the peq plug,its not a manual but it shows how to wire up a zapco peq
Nov 07, 2010 | Zapco Car Audio & Video
...storing noise detected from my
Storing as in Distortion? If that's the case lower the output gain from your amp until it is suitable to you ears. It might be all the way open, besides this should be adjusted system to system.
May 31, 2010 | Zapco Reference 650 Car Audio Amplifier
Zapco DC Reference 750.2 problem
If the amp uses TIP35Cs and TIP36Cs, those will be the output transistors. Measure the resistance between legs 2 and 3 for each of the output transistors. Do any read near 0 ohms?
If you're new to repairing amps. The following page should help.
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
Nov 16, 2009 | Zapco Reference 750 Car Audio Amplifier
Bass only going to rear speakers. How do I get
Hello michaelandta,
Check your filter settings on the front channels. It sounds like they may be set to "high pass" which would eliminate the bass frequencies. If you are using the amp to power normal speakers, it's usually best to set the filters for "full range". If the amp only has "low pass" and "high pass" settings, turn them both OFF.
Hope this helps.
Sep 11, 2009 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
ZAPCO 9.0
Go here first http://www.zapco.com/ Good Luck
Aug 06, 2006 | Zapco C2K-9.0XD Car Audio Amplifier
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
