Question about Epson R1900 Printer
SERVICE REQUERED Note. the printer is new,
  • 58 Answers
Try checking for any paper remain inside in case you printed something.If not try reinstalling the cartridges.Still same have it replaced as log as it is in warranty.
Posted on Mar 31, 2011
    Brigadier General:
  • 10,406 Answers
> the printer is new
Take it back to where you purchased it, and exercise the WARRANTY to get them to repair or replace it.
Hp 500 ploter adjustment karne pra 22:10 errer cord ata he
System error 21:10 is generated when the printer has detected a fault in the Service Station. Causes of this error can include the Service Station or Carriage. Follow the steps listed below to accurately troubleshoot the issue, and replace the appropriate parts.
Part Description Designjet 500 Models - C7769B, C7770B, C7769C, C7770C Designjet 800 Models - C7779B, C7780B, C7779C, C7780C Service Station Assembly (Required) C7769-60374 C7769-60374
    NOTE:If Removal and Installation instructions are needed for reference during any repairs performed, refer to the HP Designjet 500 and 800 Series Service Manual available on the Computer Care Web site for review or download. Troubleshooting steps If any of the troubleshooting steps listed below solve the problem, attempt to verify printer functionality (instructions listed below). If functionality is verified, no additional parts should be replaced.
      NOTE: The printer's current firmware revision must be A.02.04 or higher for a new Service Station to work properly. If firmware is lower than A.02.04, download the newest available firmware before continuing with the remainder of this document.
      1. Turn the printer off, then on to verify error. If no error attempt to verify functionality.
      2. If the error appears or problems persist, continue with the remaining steps.
      3. Follow the steps directly below to unlock the Carriage from the Service Station:
        1. Highlight the Set-Up menu and press the ENTER button.
        2. Press the UP arrow and ENTER buttons simultaneously and press the ENTER button.
        3. Highlight Service Utilities and press the ENTER button.
        4. Highlight Unlock Carriage and press the ENTER button.
        5. Unplug the power cord from the printer.
      4. Manually move the Carriage assembly out from the Service Station area and check for obstructions (remove as needed).
        NOTE: If you are unable to release the Carriage by the previous process, remove the right end-cover and locate the main Service station gear (as pictured below in Figure 1) and rotate it counter clockwise approximately four revolutions. The Carriage assembly should now be free from the Service station. Figure 1: Service Station Gear
        1. If an obstruction is found and removed, plug the power cord in, turn the printer On and attempt to verify functionality.
        2. If no obstruction was found or the problem persists, continue with the remaining steps.
        3. Disconnect the power cord from the printer.
        4. Remove the right end-cover from the printer.
        5. Open the top cover and manually move the Carriage to the left so that it is not over the Service Station (refer to Step 3 for instructions).
        6. The Service Station flag should be at about a 45-degree angle as pictured below in Figure 2.
        Figure 2: Service Station flag correctly positioned
        1. If the flag is correctly positioned continue with Step 16.
        2. If the flag is not at a 45-degree angle, press in gently on the bottom of the gray and rotate the bottom of the flag to the right (toward the back of the printer) until the top of the flag clips into the tab on the Service Station. The flag should stay at about a 45-degree angle.
        3. Plug in the power cord and turn the printer on.
        4. If no error appears, attempt to verify functionality.
        5. If the error reappears continue with the remaining steps.
        6. Turn the printer off and disconnect the power cord.
        7. Replace the Service Station assembly (refer to pg. 8-52 of the HP Designjet 500 and 800 Series Service Manual).
          NOTE: The printer firmware must be upgraded to A.02.04 or higher for the new Service Station to work. The new Service Station does not have an Aerosol fan and older firmware will check for the Aerosol fan, thus causing another system error.
          1. Following replacement, turn the printer on and verify functionality as instructed below.
          Verifying printer functionality
          1. Turn the printer on.
          2. Allow initialization to complete.
          3. Load media into the printer.
          4. From the main front-panel menu, select the Ink menu and press ENTER.
          5. Select Troubleshooting and press ENTER.
          6. Follow the instructions on the Front panel.
          7. Following a successful troubleshooting print, functionality is verifie
Sep 16, 2013 | HP Hewlett Packard Designjet 500 42" Wide...
System mechanic pro won't start error message
I went through the registry and searching for 'iolo', I deleted all references. Then deleted the files under program files. This worked. I tried going to the hex keys by themselves and that did not work. But I was deleting System Mechanic and Not "PRO".
Aug 28, 2012 | Iolo Technologies System Mechanic: Windows
I need a new printer head printer 3250
We've determined that the printhead for your printer may be in need of replacement.
We will review your service history to determine if your printhead usage suggests that another course of action is required to solve your problem. To expedite this process, please complete the mandatory fields below. If we determine that a printhead replacement is necessary, the new printhead will arrive within 3 to 8 business days.
NOTE: If a mandatory field is incomplete, shipment of a new printhead will be delayed.
Kodak Service Number
(7-digit number located under the printer access cover) Call Kodak: All-in-One Printer Phone Support Live telephone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight, Eastern Time, 7 days a week. The expected wait time for phone support is 15 minutes.
Dec 04, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Jam in tray 2
This is an update to:
HP LaserJet P4015 - Not Picking Up Paper
HP now recognise this as a manufacturing fault and have released a service note for it and will send you a new fuser free of charge. The description of the fault is:
When a print job is sent to the printer, the printer will display processing job on the control panel, and will continually ramp up and down attempting to print the job. After several minutes the printer will return to ready without posting any error messages. Occasionally, after several minutes the print job will print.
The fix for the fault is:
The fuser needs to be replaced and firmware needs to be upgraded to version 04.060.7 or higher.
The customer will need to download the latest firmware from hp.com, version 4.060.7 or higher. The firmware can be downloaded from hp at "hp.com/go/support" . Select Download drivers and software (and firmware) in step 1 and in step 2 type in the printer name, LJ P4014, LJ P4015 or LJ P4515
It's probably best to update the firmware before you phone HP to report the fault, or at least tell them you have. If you do update the firmware, you will notice some extra numbers and letters on the display when the printer initialises. This is normal, it's probably used by HP staff for diagnosis.
The fuser is a customer replaceable part, and does not require a service technician to install. If the customer requests a service technician to install the fuser the customer will be responsible for the labor. The fuser can be sent directly to the customer with instructions to upgrade their firmware.
What this means is that HP will send you a new fuser to fit yourself.
The models covered by this service note are:
HP LaserJet P4014 Printer series, HP LaserJet P4015 Printer series, HP LaserJet P4510 Printer series.
EFFECTIVE DATES
Start: 2010-01-01
Expiration: 2010-12-31
What this means, is that HP will send you a new fuser for this fault until the end of 2010, although they do sometimes extend the active time period for service notes.
Hope it helps..
Thanks for using fixya......
Nov 08, 2010 | HP LaserJet P4014n Printer
Paper not feeding correctly , used directiions from canon to clean rollers, nothing is stuck in the printer
Although you can't see something, I believe there is something stuck, i had the same problem and manage to find and earring and £5 note!!!!
Please email me and i'll explain how i found and got them out :-)
Davinia.uk@gmail.com
Dec 07, 2009 | Canon MP520 All-In-One InkJet Photo...
Nero 9 Trial seriol number requered
DEAR SIR
PLEASE USE THE FOLLOWING SITE TO DOWNLOAD THE CRACK FILE ( SERIAL NO) FOR AHEAD NERO 9
REGARDS
MURALI
Dec 31, 2008 | Ahead Software Computers & Internet
Please help me
requered driver of l7 cel motorola
May 30, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Open Questions:
See all Epson R1900 Printer Questions
Epson R1900 Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
