My 27" Darfon tv's screen
  • robwilson090 Apr 01, 2011
    I'm not sure what a ballast is or looks like, any pointers to help me locate it. Sorry but this is my first time at trying to repair a tv. Thanks
  • 6,993 Answers
I think you need to check the ballast. The ballast ignites the lamp. A defective ballast to cause your screen display become dull or dim.
So, you might also need to replace the ballast.
Lastly, power problem could cause this type of problem. When the power board is not supplying full current into other parts of the TV, this can cause the display to become dim. So it is also possible that low voltage circulation in the TV is the cause of the problem. Check the power supply board for any short or obviously bad capacitor or any other component on the power board.
But check check the ballast first, if that doesn't fix things, then check the power supply board.
Good luck.
Posted on Mar 31, 2011
  • Walesarumi
    Walesarumi Apr 01, 2011
    This is what the ballast looks like;
I have a 52pfl7403d/27 and when turned on a square black box takes up 1/4 of the TV screen. I'm thinking backlight inverter. Any clues?
look instead in the menu under closed captions-----text feature is turned on in the set OR on a box if one is used.
If Text feature box will be near the middle of the screen, what do you have?
Apr 27, 2012 | Philips Televison & Video
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
How do I turn on the closed captioning without remote?
Look for a button said Menu on the tv manual bottons on the bottom of the bazel frame of the tv.Push that button.Go into tv menu look for Captioning Functions.Have Closed Captioning CC1,2,3 or TEXT 1,2,3 turn it all off.Will have no more close captioning or black boxes,will pop up on ur tv screen.
Jan 06, 2011 | Orion STV2763 27" TV
The image of my optoma hd803 became inverted.
Go into menu settings, look for a menu item that has to do with screen size and orientation. You'll be looking for the option to rotate the image for mounting the projector upside down on a ceiling mount.
Feb 06, 2010 | Optoma HD803 DLP Projector
My bottom part of tv to the left side became a little wavy and it's showing double and you can see also letteing in red color.
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 07, 2009 | Panasonic PT-53TW53 53" Rear Projection...
The convergence is out
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 21, 2009 | Samsung TXN2771HF 27" TV
Hitachi Projection tv
*Screen Looks 3-D
*Colors wont align
Jul 17, 2008 | Hitachi 43F300 43" Rear Projection...
No picture on Westinghouse W32701 LCD Model
Screen goes black, sound unaffected. Can be remedied by turning off and immediately back on, but it will do it again and again and again.
Nov 11, 2007 | Westinghouse LTV-27w6 27 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
