Question about SIM2 HT380 Grand Cinema DLP Projector Projector
We have a replacement bulb and I don't have a trap door to remove the old and install the new.
    Problem Solver:
  • 6 Answers
WARNING! Sim2 does does not recommend that you change the lamp, they recommend that you contact a local dealer for service. PROCEED WITH CAUTION!
If you still wish to proceed. This instruction is available at avsforum
http://www.avsforum.com/avs-vb/showthread.php?p=17983282
There are 2 recessed screws on the bottom near the front of the projector (really deep cavities). There are 2 on the backside of the unit. Remove all those and the top cover comes off. Inside you will see a fan held on by 3 screws (you will know it because there are 4 holes, but only 3 screws...that is normal). Remove those and take that fan module off. The lamp is then accessible.
Good luck! __________________
Jason C. Turk
Consultations, Installations and ISF Calibrations
585-671-2968
jason@avscience.com
Available for scheduled consultations...please contact the main office for details!
Posted on Mar 31, 2011
N12pI how to replace Ram
underneath there should be a small trap door secured with a screw. With the laptop off, unscrew this door and remove the old chips by pushing out of the side clips. lift out old ones and insert new ones, paying attention to the slot in the chip lining up with the motherboard and then push in and lay it back. Put back trap door
Dec 02, 2013 | Twinhead SlimNote N12PI Notebook PC
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Never replaced a headlight on my 1996 saturn sl1 and now I need to. I bought the Sylvania Xtravision 9006 bulbs but the owners manual is no longer with the vehicle and I don't want to break anything...
ask a local mechanic to install for you providing that this high intensity bulb is allowed to be fitted in your country as here in spain they are not allowed unless the headlight has a special code in the number which is the certificate of homoglonation .Well this is spain and they do love the old paperwork ,dont the bulbs fit in from the back with a clip ?¿? most do but some vehicles you need to remove the headlight to fit a new bulb
Jul 13, 2011 | Saturn SL1 Cars & Trucks
How do I change the projection lamp for my sony kds 60A3000 60in tv?
remove the front panel below the tv screen. Look for a small door with a single screw. Remove the door and slide out the old bulb. Install the new bulb and reverse the steps!
Thank you and best of luck!~
May 27, 2011 | Televison & Video
How do i change the bulb
Bulb TVs are very big. In most cases the TV will give a warning that alerts you it's time to change the bulb. Do not touch the glass part of the bulb, as oil from your hands will reduce the life span of your bulb. Replacing the bulb is a simple process that will take a few minutes. Here is how to do it.
Step 1: Read User Manual Make sure that you have your user manual with you when working on your TV. Most electrical appliances will have guides on how to deal with replacements of parts and where to get the replacements and what specifications to look for. Read the user manual in depth before attempting the project of replacing the bulb. Step 2: Disconnect Power When working with any electrical appliance, always switch off and disconnect the power. Electrical shocks can cause injury or even death. Step 3: Open Bulb Door At the back of the TV there will be a bulb door which will usually be near the power cord, depending on the make of the TV. Once you locate the door, proceed to open either by sliding it open or unscrewing it as may be required. Step 4: Remove and Replace Bulb Once the door is open, unscrew the bulb assembly and remove it. You can then remove the bulb from its compartment. Bring out the new bulb. Hold up the groove on top of the new bulb and align with the groove pocket on the inside of the TV, then proceed to slide the new bulb into place. Step 5: Replace Bulb Assembly Once the bulb is securely held in place, return the bulb assembly to its position and screw it back. Make sure not to tighten it too much but have the screws just firmly in place. Step 6: Close Bulb Door Once you are finished, you can close the bulb door after making sure there are no tools or screws left inside. Having such items inside the TV could cause a short circuit. Your door needs to be closed for the TV to operate. Tips: Remember to allow the old bulb to cool before you remove it. It will usually heat up to very high temperatures that could cause some serious damage. Most TV bulbs will warn you to replace your bulb while about a hundred hours are left on the old bulb. This duration is meant to give you time to get the replacement bulb and fit it. Finally, if you do not feel confident in doing the replacement yourself, get a professional to do it for you. They might charge you a fee, but it will be cheaper than the cost of damage caused by a poor fit.
Take care in solving the fault
May 12, 2011 | Zenith R57W46 57" Rear Projection...
How to replace a bulb
Hello
To replace bulb in RCA rear projection TVs follow this.
Turn the lamp assembly so that the front of the bulb faces downward
Locate two clips approximately three inches apart along the back edge of the rear lamp cover. Depress the clips with your thumbs and pull upward on the rear lamp cover to disengage it. Move the rear lamp cover so that you can see the head of the bulb. Note that the rear lamp cover still connects to the base of the bulb by a cable.
Locate the three hex screws around the head of the bulb that, in a triangle formation, secure the bulb to the assembly. Remove the screws with a hex screwdriver.
Pull the bulb and rear lamp cover upward to remove them.
Remove the nut that connects the cable from the rear lamp cover to the base of the bulb with a wrench. Disconnect the cable from the old bulb and discard the old bulb.
Reattach the cable from the rear lamp cover to the base of a new bulb and install the nut. Tighten the nut with a wrench
Install the bulb face down into the lamp assembly. Install the three hex screws into the tabs along the edge of the bulb and tighten with a hex screwdriver.
Reinstall the rear lamp cover onto the lamp assembly and line up the tabs with the holes along the side of the assembly. Press downward until the cover snaps into place.
Reinstall the lamp assembly into the back of the television, facing the bulb towards the center of the TV set. Tighten the screws securing the assembly and reinstall the lamp access door. Tighten the screw on the lamp access door.
Mar 22, 2011 | RCA D61W20 61" Rear Projection Television
Replacing the window regulator
1.Remove trim from around the door handle by prying it out along the top and front edges. Once loosened, it comes unhinged from the back edge.
2.Remove the Phillips head screw from metal bracket, that is revealed after removing the trim piece
3.Pry the inside light assembly from the door panel and remove the bulb socket from the housing
4.Pry the door panel from the frame using a panel removal tool by starting at the bottom and releasing the 7-8 plastic studs from the frame.
5 - Remove the 2 mounting bolts for the rear door controller and disconnect the cables.
6.Use a small flat blade (e.g. scraper) and flathead screwdriver to remove the plastic vapor barrier (be careful not to tear as it must be replaced).
7.Reach inside the door and locate the cable that is attached to the bottom of the lift mechanism and then cut it.
8.Push the window class to the full UP position (this will locate it horizonally and vertically) and tape it in place.
9.Near the top of the sheet metal there will be 2 openings (1 square, 1 round). When the glass is in the full up position, there will be (2) 10 mm bolts in view. Loosen these bolts which will open the rubber coated clamps on the bottom of the glass. The lift mechanism will free fall to the bottom position when these bolts are loose.
10.Remove the window lift motor plug and (3) 10 mm nuts that hold the lift mechanism in place and remove through the opening at the front of the inner door sheet metal.This will require some maneuvering.
11.Loosen but do not remove the 2 bolts for the window clamps on the new unit before installing.
12.Make sure the new unit is not in the full up position before installing.
13.Install the new lift mechanism in the door and tighten the (3) 10 mm mounting nuts.
14.Connect the power plug into the new lift motor
15.Temporarily connect the rear door controller, turn on the ignition and slowly raise the new lift mechanism using the window up switch on the driver's door.
16.Then the lift is in the full up position, tighten the window glass clamps using the same access holes as when you removed the glass clamps.
17.Slowly run the window down and up to make sure it doesn't bind
18.Disconnect the read door controller and reverse the process for assembly
19. Make sure the rear door light socket and bulb are not trapped behind the plastic.
Hope this was helpful!
Dec 03, 2010 | 2001 Buick Century
How do I dismantle the projector bulb carrier from a Sony Grand Wega KF-42E200A? It only costs $90 for a new bulb, but $200 for a new bulb & carrier assembly. How difficult is it to remove the bulb...
the lamp door is on the right side, pop it open and there will be another door with a knob on it. Turn that knob counter clockwise to unlock it and pull it out. Inside that door you will see the handle for the lamp, put your finger through the loop and pull up and out at the same time, to put in the new lamp, push lamp straight in until it won't go in any further and puch down, it should then be locked in place. Replace both inner door and outer door and you are good to go.
Someone mentioned something about cleaning the dust from around the lamp. I tried that before I got my new lamp. It only worked for a day and gave out again. Hope this helps.
Nov 27, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Bulb is out
First unplug the AC feeding the set look in your owners manual for location of lamp door cover you may need a flat head screw driver. After locating the door and lamp it is just remove old lamp and firmly install new one do not get finger smudges on new lamp or try LG for help on line an online search for their customer website there you should find instructions to replace lamp
Aug 30, 2008 | LG RU-52SZ51D 52" Rear Projection...
DLP bulb replacement
most manufactures consider the lamp to be a consumable product so the will give you instructions in the box with the new lamp..basicaly,,you unplug the set..remove the lamp cover door,,remove the old lamp,,install the new lamp,,replace the lamp cover door, plug in the set...some companies want you to reset the lamp timer and that info is in the owner manual..get an original lamp and not a generic one..call the manufacturer with you model number and they will most likely sell you one and ship it to you
Nov 27, 2007 | Televison & Video
SIM2 HT380 Grand Cinema DLP Projector Projector Logo
184 people viewed this question
Top SIM2 Office Equipment & Supplies Experts
jasbo
jasbo
Jerry Umali
Are you a SIM2 Office Equipment and Supply Expert? Answer questions, earn points and help others
