Question about JVC AV-32D305 32" TV
Dropped my 32" tv...the table
    Genius:
  • 1,126 Answers
It sounds like you tv need degaussed and you also could have it setting to close to speakers. Unplug the TV for 30Mins, from the wall and when you plug it back in and turn it o0n the degaussing circuit built inside the TV should fix it.
Posted on Mar 31, 2011
When I used grandfathers old table saw with ungrounded cord. It worked fine, I then plugged a jig saw into same outlet. It worked fine. When I laid the jig saw on the table saw there was a spark a
Check the plug that goes into the outlet. On modern plugs, one prong is taller than the other. The taller is the "ground" leg - the other is the "hot" leg. I bet that you just need to flip the plug over so that the other prong is in the "ground". If this works - mark the "ground" leg (or replace the plug with a newer one that has a taller "ground" leg).
Sep 16, 2014 | Saws
Table broken leg
You need some kind of screws/bolts to hold the broken pieces in place before you can apply glue. At the end of your video, you showed the bottom view of the legs. If you can drill some holes at good positions, you should be able to put bolt and nut to hold the legs in place. Then, you can use super glue to keep the surfaces smooth.
Apr 11, 2014 | Furniture
I have a Haier Hl32d1 32 in. TV. When I watch for a while the colour gets all messed up and become bright pastel colours like a lava lamp.
Hi Jesse, This is interesting. Please open the menu in "Lava like state"If the menu comes ok it is the main board causing this problem and if the menu does not appear properly, it may be due to bad display unit. Please consult some qualified technician.
Jan 08, 2014 | Haier HL32D1 32 in. TV
Component input colour is messed up
Go to the back of the TV and make sure, the component cables are inserted in all the way. Do the same for the source (cable or satellite receiver) component cables should be firmly inserted.
Try narrowing the problem by testing the TV with a different source, such as a DVD player if it compatible with the component. If the TV works with the DVD then your TV is fine and the problem goes back to the source (Cable or Satellite Receiver)
If the TV still not showing natural colors after been tested with another source.. then, the TV may have a bad PCB.
Best of Luck
Nour BMI
Feb 05, 2010 | LG 32LG30 32 in. LCD HDTV
I need thd legs for the tv
Did you ever find the legs/table stand for this TV? I'm looking for the same.
Nov 29, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Tevion tv won't display normal colours on PAL 60 setting
Look behind of the TV for trim adjust potentiometers. If there are any of them, you shall open your tv's backcase, look for Crominance trim and adjust it manually. If you have no electronics knowledge, i wouldn't not recommend do it "for pratice", you may distroy the TV, end in the hospital, or into a coffin.
Nov 20, 2009 | Televison & Video
All buttons control tv/video, remote stopped working
Unplugged it for an hour.... buttons changed.....Unplugged it for four hours and everything worked......Left it plugged in overnight and back to original problem....
Oct 02, 2009 | Toshiba 32A33 32" TV
Mario all stars colour problem
Maybe the intenal part inside of the gamepack could have gotten busted by now or its a crappy gamepack that was purchased so buy one that actuallys works and through this one out.
Feb 09, 2008 | Nintendo Super NES Console
Colour on tv is all purples and greens
Was the tv dropped?--try manual de-gaussing.If that does not
work,the problem may be the shadow mask inside CRT or the
yoke is loose and mis-adjusted on the neck of CRT.
Oct 13, 2007 | Sharp 32C-240 32" TV
JVC AV-32D305 32" TV Logo
75 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
