Toshiba e-studio 45
Good day!
I have already clean the primary and the optics and after cleaning the copy is alright again but still after sometime the dark page returns. We don't know the problem because we already overhaul it but still the dark page comes out. (For info the whole page is dark)
Thanks again.
Hi ms
i need scaner driver of estudio45 . plase help me.
tank a lot.
Posted on Feb 24, 2009
    Problem Solver:
  • 19 Answers
You must have to change primary
Posted on Feb 11, 2009
HOW DO I CLEAN THE MACHINE SO IT DOESN'T LEAVE A BLACK GRITTY RESIDUE ON PAPER CHANGED INK ALREADY
Get an inexpensive toner vac if you are cleaning a spill. If the pages are coming out of the machine with toner on them can you post a pic?
Mar 27, 2014 | Toshiba e-studio 255 Copy Machine
The developer box does'nt keeps toner in it, is it probably because of already 'old developer' or do i need to add some developer...how much is developer? Mine is toshiba e45. Thanks a lot.
Hi
The developer life span is about 150.000 copies, then it should be replaced.
If the developer has not done 150.000 copies then there could be another problem.
The cost of the developer is about R1000.00. {in South Africa}
Please remember that the life span of the drum and drum cleaning blade is also 150.00 copies, so the developer, drum and cleaning blade should be replaced at the same time.
Regards
Apr 12, 2011 | Toshiba e-Studio 45 Black and White Copier
Toshiba e-studio 3511 has printing issued on one
These copiers have serious toner dust issues. Light copies are usually caused by dust in the optics (the mirrors) and on the laser glass.
Take off the main copy glass and gently clean all the mirrors and scan bulb underneath it - be careful.
If you remove the drum unit and look inside the cavity you took it out of you will probably find a huge toner mess. the laser glass is situated in this cavity and needs to be cleaned - just clean whatever you can see...
Feb 01, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba e-studio 45
did you fing the problem???
Aug 12, 2008 | Office Equipment & Supplies
Toshiba e-studio 45
sorry no manual, the seperation is the unit that is directly opposite the drum, it is a black unit with wires
Aug 09, 2008 | Office Equipment & Supplies
Problem on Toshiba e-studio45
Yes, that could give you dark copies on one side of the copies... I use a glass cleaner to clean of the primary charge roller or grid. wipe them off with out getting any thing on the OPC drum it self. Did you clean the optics already?
Aug 04, 2008 | Office Equipment & Supplies
Problem on Toshiba e-studio 45
I beleive that if there is a problem with the primary you will only get a blank copy not black.
the problem is most likely your Seperation ***'y or the drum.
1- either the sep/***'y is shorting out causing the paper to rise against the drum and putting too much toner output, or the drum has not been adjusted correctly. Did the tech adjust the new drum to the machine? there is a procedure you have to do everytime you change the drum.
Gear easily worn out on Toshiba e-studio45
The dark copies could be that you need to clean your optics aswell, they are under the copy board glass. If the mirrors are dusty you will get alot of back groud in your copis and poor C.Q. I would just use a dry cloth to wipe the mirros off, should be three. Also, I would use a cloth with a little alchol on it to clean the lamp.. Almost forgot turn the copier OFF first. The small gear could be that there is another problem with the developing unit.... There may be a worn out bearing or seal... It should last longer.. Is this the second time it will need replacing? If so you may have to look alittle deeper
Jul 23, 2008 | Office Equipment & Supplies
That should be looked at by a technician to check the optics out
Jul 13, 2008 | Office Equipment & Supplies
Copy quality
Try cleaning the laser.
Jul 02, 2008 | Toshiba e-Studio 161 Copier Copier
69 people viewed this question
k24674
jasbo
jasbo
