Question about Nelson Sprinkler: Traveling Tractor
T fitting on top of tractor that the sprinkler arms attach to
To remove: Hold the plastic nut under the "T" arm assembly and use your other hand to unscrew the "T".
To replace do just the opposite. Do not over tighten, you can crack the retaining nut.
Posted on Apr 15, 2011
Sprinkler arms came off and water shoots straight up
You just have to screw the arms back on. There is a plastic white bolt that is attached to the arm it screws on to the tractor.
Sep 04, 2013 | Nelson LR Rain Train Traveling Sprinkler...
Nelson Sprinkler Rain Train Traveling Sprinkler will only go backwards , i have the arms going in the right direction...please help
If it's going backwards, and assuming you didn't take it apart and put it together wrong, then the arms aren't going in the right direction. Looking down from the top, my unit should be moving clockwise if it's set up correctly. In any case, switch it so the water pushes the arms in the other direction. the transmission is pretty straightforward - if it's going in the wrong direction then the arms are spinning in the wrong direction.
Aug 02, 2011 | Nelson Sprinkler: Traveling Tractor
My tractor sprinkler was running fine and then suddenly stopped. What should I look for as the problem?
My sprinkler did (something like) this a couple of times (very infrequently) - the arms seemed "seized" (cannot rotate clockwise or counter clockwise) but, I was able to get them moving again by picking up the sprinkler (a couple of inches) by the sprinkler arm T-pipe. Picking it up this way, vertically, seemed to "un-stick" the arms.
Of course, if your sprinkler is very old (12 years?) the gear box may be worn, it would cost about a quarter to a third as much as a brand new sprinkler to replace. You can find the parts you need by reading the question about where to get parts at FixYa.
Jul 02, 2011 | Nelson Sprinkler: Traveling Tractor
Tractor sprinkler. the plastic t that attached the arms has broken. i ordered a new part with the t, and two new sprayer arms. cant figure out how to remove the broken t. tried pulling as i unscrewed...
Make sure you are holding the shaft that goes down into the tractor still. You may need a pipe wrench to hold it tight. If it is still stuck you may need to use something like PB blaster to loosen the joint. Gently heating the joint with a propane torch and letting it cool back down might break it free as well.
Jun 06, 2011 | John Deere Gilmour Traveling Sprinkler -...
The watering arms won't turn to move the tractor
Check your water pressure... you need to have 40-60 PSI.
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Nov 17, 2010 | Nelson Sprinkler: Traveling Tractor
The sprinkler part came flying out of the sprinkler! What can I do?
which part? The arm??? Put it back in and tighten the palstic ens where the arms go in. If it was the whole top piece put it back and turn the arms the other direction, mak esure tractor is going forward.
Jul 30, 2010 | Nelson Sprinkler: Traveling Tractor
Need tractor parts
I found this Nelson website to be the best. Good luck! http://www.lrnelson.com/products/files/1865_2001C.pdf
Jul 20, 2009 | Nelson Sprinkler: Traveling Tractor
Nelson traveling sprinkler broken plastic part
I just took mine apart about a week ago. If, I recall correctly, you broke the T piece. That black plastic or nylon nut that is still connected to the transmission should thread off fairly easily.
I expect you can buy the part from Nelson.
If, solution #1 is correct and you find you cannot get the part, I've done some truly amazing repairs with that epoxy product called PC7. Depending how much of the part is broken and or missing, you might find a combination of what you have plus a brass T fitting plus the PC 7 will get it working.
You have nothing to loose.
Jul 16, 2009 | Nelson Sprinkler: Traveling Tractor
My tractor runs backward
You have to turn the sprinkler arms in the opposite direction to what they are. There is a diagram on top of the sprinkler.
Jul 15, 2009 | Nelson Sprinkler: Traveling Tractor
Nelson Sprinkler:  Traveling Tractor Logo
145 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
