SAVED A DOC ON SKY WHERE IS IT AND HOW DO I ACCESS
    Brigadier General:
  • 10,406 Answers
> where is it?
On SKY.
> how do I access?
Login to SKY, and it will be available.
Posted on Mar 31, 2011
I cannot open my document that i just saved, please help!!!
Make sure the document isn't already open, then check the recently opened folder.
Mar 01, 2011 | MSI Wind U100-280US Netbook
Links do not work in Pdf saved file
Don't panic,many people face this problem.You can use a third-party tool,such as advanced word to pdf 5.0,It is good in preserving the formatting.
source:http://www.advancedpdfconverter.com/products/wordtopdf.html
Jan 11, 2010 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
Need new codes for telepest
Don't know if this helps but I too had lost programs this morning 9/10 but i just put in yesterdays codes saved and they all came back
Oct 08, 2009 | StarTech.com StarView SV211K 2-port KVM...
Sky Plus Planner shows message Please Wait and nothing happens. Cannot therefore play previously recorded programmes or record new ones.
try formatting your hard drive, you will loose all the saved programmes but it may fix ur problem.
follow instructions:
http://nice-design.co.uk/blog/sky-plus-system-fault-how-to-fix-faulty-sky-without-a65-callout-fee
Oct 28, 2008 | Televison & Video
Using Word & Excel mobile
I saved an empty blank Word doc. and excel sheet. to my phone via Microsoft Active Sync. Now I just open the blank doc. edit the file, and save it as a diffrent file name. I'm still left with the blank doc. and an edited file.
Jul 30, 2008 | T-Mobile Dash Smartphone
Foreign systems in a micro soft word doc.
Whatever you opened the document in hasn't recognised the format you saved the document as. By that i mean, notepad can't read Microsoft Word Documents, etc. What did you open the 'saved document' in?
Jul 14, 2008 | Acer NSK8458AN Keyboard
Saved document is now lost
I strongly suspect that the files have been saved to a directory that you were not intending to use, hence my suggestions to locate the files.
First option: Open the program (a blank document will do) and select File - Save As . . .
Look at the top of the dialog box and check where the files are being saved to. If the files are there and the location is not where you thought it should be - select the files you want and RIGHT Click these, select copy (for safety) and manouvre to the Folder where you want the documents to be located (use the drop down list at the top of the dialog box) - when you have opened the correct location, Right Click in the opened folder and select Paste.
You will still need to go into the Tools - Options menu in the program and find where files are automatically saved and change this to your desired location. This saves having to check the Save As . . dialog box everytime you want to save a new document.
Second option: Open Windows Explorer (not Internet Explorer) which can be found under the Start Button - All Programs - Accessories. In the Search box either type in the name of the document (if this is known) or just *.doc (or whatever the extension is eg *.xls). Note the "*" is a wild card symbol which means that it will match any and all letters or numbers in any combination and then followed by ".doc". This will find ALL documents that end in ".doc" not just the ones you are looking for!
The first search will only find files in the open Folder that match the query. I'm guessing that your files are not there. Now select Advanced Search and select C:\ to be searched. This will now find ALL files ending in ".doc" on the hard drive.
View the results as "Details". Locate your files (select "name" as the sort order to make this simpler). If you had a new document and just hit the Save button (or selected Save under File), then the files could be named as the first few words of the document - so look for this as well.
In the details section will be the Pathway to the files (eg C:\Samsung\Inprocessor\Drivers\Resume.doc). You can then go to this directory and using Edit - Cut (or Copy) remove the file from there, then open the directory that you want the file to be placed in (eg Documents) and again using Edit - Paste to put the file into that directory.
Good luck.
Apr 06, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
David Payne
David Payne
