Question about Cell Phones
I have a HTC HERO phone and it is not charging. I try other batteries and still not charging. I try a new USB cable but still not charging. I try it on my computer and still none. Please I need an assistant now .. if there will be any changing parts please tell me how much it will cost. Im here in the Philippines. Thank you
  • Cell Phones Master
  • 6,993 Answers
I don't know precisely where you can get a charging port replacement because we don't stay in the same vicinity. You can ask from a friend where phone parts are being sold.
Read this tip and know the possible reasons why your phone won't charge. It was posted by me; http://www.fixya.com/support/r8742993-phone_charge
I hope this helps and point you to the right direction....
Good luck.
Posted on Mar 31, 2011
Phone wont charge
Good Morning My Dear;First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 30, 2012 | HTC Hero Smartphone
HTC Hero won't charge. I bought a new battery...still won't charge. I've tried a wall charger and a car charger and neither of them work.
U can call your service provider they might be able to help ifthey cant assist you contact the phone manufacture either way you will get ananswer to your problem.
Sep 01, 2011 | HTC Hero Smartphone
I have a htc h7 from tmobile. i have pics on my phone and wanna download the pics to my laptop into a folder. how do i do that?
Hi there!
You can transfer the pictures from your HTC Hero to your laptop using a USB cable.
First, make sure that you're phone is turn on. Connect the usb cable to the computer and to your HTC. Once you connected the phone & the computer, there will be a USB Connected option that will appear in your phone. Choose "mount." Open my computer and a new USB drive will appear. Open it and look for "DCIM" folder. Open that folder and open the folder named "100Media," that contains all the pictures from your camera.
Hope this helps.
Apr 30, 2011 | HTC Hero Smartphone
How do you get the upgrade the htc hero to 2.1
Getting Started
Before you run the ROM Update Utility (RUU), make sure you have done the following:
  • Backed up the data on your device.
  • Standby or hibernation mode of your PC has been disabled.
  • Close all running applications on the PC.
  • Set aside approximately 25 minutes to allow the device to update.
  • Charged the battery to at least 30%.
  1. Download HTC Sync for Android.
    Install the HTC Sync software on your PC if it is not already installed. This software was included in your HTC Hero gift box. The minimum required HTC Sync version is 2.0.28. We have HTC Sync for Android 2.0.40 available for download; newer versions might be available from www.htc.com.
    HTC Sync for Android 2.0.40 (39MB)
  2. Download the Hero 2.1 MR Upgrade executable file.
    Hero 2.1 Upgrade (113MB)
  3. Connect your HTC Hero to your PC.
    Use the supplied USB cable.
    If the HTC Sync application appears on the screen of your PC, you may simply dismiss the wizard by pressing the Cancel button.
  4. Run the Hero 2.1 MR Upgrade RUU file.
    Follow the on-screen prompts to install the update for your HTC Hero
WARNING: During the upgrade process, do not attempt to make/receive calls, press any buttons on your device or disconnect the device from the USB cable as this will stop the update and your device may be rendered inoperable!
If you have a problem with the connection between your device and PC be sure to check the connection type in your device. This can be done in the device via Settings -> Connect to PC. Ensure that HTC Sync is selected.
Mar 09, 2011 | HTC Hero Smartphone
Sir how can i connect my htc hero phon to pc
sir please install the htc cellphone pc suit to the computer.then connect the datacable from phone to the computer for transfering the files................
Jan 14, 2011 | HTC Hero Smartphone
HTC Hero(w/ google, not refurbished) is not charging. If I plug it in, it holds the battery level at whatever level that battery is, and every time i unplug it the battery just gets lower, and never...
If you are plugging it into the usb port of a computer then you may not be getting quite enough power, try plugging it into the wall via the wall charger and see what happens. If nothing happens I suggest taking it into the store you bout it from and letting them see the problem, a lot of them have policies for fixing this sort of situation.
Dec 30, 2010 | HTC Hero Smartphone
I just got the htc hero and for some reason it says its charging but the battery never gets charged. once i take it off the charger (be it usb, car, or plug), it immediately tell me the phone is dying. ...
See if there is someone with a Hero and try their battery out. It sounds like your battery is not holding its charge anymore. If you just got it, take it back to the store and see if you can get a replacement.
Good luck.
Oct 05, 2010 | HTC Hero Smartphone
How can I connect my htc hero to my laptop
You have to connect the HTC hero to computer via the USB cable. Then you will find a USB logo in the notification bar. Drag than down and select DISK Drive in that menu. Now the phone's memory will appear as a removable drive in your computer.
May 30, 2010 | HTC Hero Smartphone
I want Modem Driver for HTC Hero phone using sprint network
Using the HTC Hero as a USB Modem
In order to use this functionality, the HTC Sync software must be installed onto the PC first (http://blog.brightpointuk.co.uk/synchronise-htc-hero-microsoft-outlook).
The HTC Sync installer is included on the SD card that comes in the Hero sales package, or alternatively is available for download from our FTP site:
ftp://ftpaccess:Brightpoint1@ftp.brightpointuk.co.uk/Technical%20Support...
You can download the software to your PC, or insert the microSD card into a suitable reader to access the software.
Once installed, on the Hero device browse to Settings --> Wireless Controls and enable the option to enable Mobile Network Sharing. Now connect the Hero to the PC via the supplied USB cable. Windows will detect the new hardware automatically and install an "HTC Remote NDIS Network Adapter": Provided that your Hero has a cellular data connection, you will now be able to use that connection from your PC.
(If you found this information helpful please rate this answer with a big thumbs up and thank you for visiting Fixya!)
Jan 27, 2010 | HTC Cell Phones
Helppppppppppppp
well u pronobley need a new battery
Nov 05, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
