Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna deluxe machine will not prime
The guy i bought it from had it in storage. It sounds like the pump is working but no water comes out. I only tried it for short period as i dont want it to overheat and damage anything. I am not sure how to acess the water line to check for a bockage or to check to see if maybe it has some sort of vapor lock.
Any info would be great
  • rvman1963 Aug 06, 2008
    Where would I find a bellows pump to try this?
  • janetind Aug 16, 2008
    I have a Saeco Vienna Superautomaitca. It hasn't been used for about 1 year and now when I first turn it on the machine will not prime. My maintenance book says to 'manually prime' the machine with the manual pump. I no longer have the manual pump that came with the machine. Do you know if I can use something else to manually prime it - or can you tell me where I can find a replacement manual pump thing?
    Many thanks,
    Janet
  • 515 Answers
try to open the steam knob and see if there will come out some water, if not then you have air in the system.
Try to take a bellowpump and press in water where the hole for the watertank in the machine are, open the steam knob so the pump is running when you do this.
Posted on Aug 05, 2008
  • Mirko Blas
    Mirko Blas Aug 07, 2008
    Try a similar pump, you only have to force in water to the machine when the machine takes water then you have to put the water tank back again.
On Vienna Deluxe after the beans are ground and ready to drop the espresso shots, nothing comes out and the red light goes on? I shut the unit off for a minute or so, turn it back on and it works ok, but...
Solid red light is a ventilate light.. Try Priming the machine to see if the light goes away.
Something may be in the flow meter. Its the while device between the water tank and the pump of the machine. You would have to open the machine and clean out the flow meter.
Also, if you haven't descaled the machine already, I would start there.
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Mar 07, 2015 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Water is not sucking from the water tank and thus no coffee is dripping from the drip. It is a saeco vienna deluxe coffee machine. Please give me any detail on how to repair this problem. I live in a...
try to prime the machine -open the hot water knob. Probably water you use is very limestone. Try with vinegar -fill tha water tank and try to prime it again.
Oct 09, 2017 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe starts brew cycle then red light comes on
Hi
I think you put the tubes on backwards to the flow meter. The inlet side of the flow meter is by the pump and the exit to the pump is by the water tank. They cross.
Jun 29, 2009 | Saeco Vienna De Luxe Espresso Machine
Stuck on ventilate
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Magic + Super Automatic -- pump doesn't work
You need to prime the machine. To do that, open the water to let water out ( this will start the pump and make the water run through all the internal componets. Do this for 10-15 sec.
Jun 12, 2008 | Saeco Vienna SuperAutomatica Coffee...
My saco vienna superautomatica has been in storage. How do I get water to pass through the machine
fill up the water tank try it if nothing coming out in the starter kit they give a plastic pump if you have fill it up with water remove the water tank in the center hole were the water goes put the pump and force water in there if you dont have the pump try to inject water in there with at turkee pump anything you got it gonna prime the pump put water back open the valve for the water on the side where you do the milk should do it cheers
Jan 17, 2008 | Saeco Vienna SuperAutomatica Coffee...
New Saeco Vienna Delux
take off the water tank and get a primer tool from saeco. (cost about 1$) is sort of a seringe.. It can also be a faulty filter in the tank
Oct 20, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna deluxe espresso machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
Jun 08, 2007 | Saeco Vienna Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
378 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
