Sir, my atek usb gamepad not work in win7.when i plug it then it told me that device not recoznecd..i already install its drivers but they can not work. please help me
  • amit thapliyal Aug 24, 2012
    i am having same problem and i also tried this method but still not working....its says code 43 error....any more suggestions plz
  • 961 Answers
Ciick on "start", then click on "control panel". Find "device manager", right click on, open and, click continue. Click on box with + next to "Human Interface Devices" Do you see a warning, ?, !, yellow triangle? If so click on that and follow recommendations. Right click on your device. In the list, you should see "disable". If you see "enable" click on that, exit. Right click on it again and click on "properties". You should see "this device is working properly". Click on "driver" tab. Click on update driver. Click on "automatically search for...".
Posted on Mar 31, 2011
  • David Petry Mar 31, 2011
    Make sure your connection is good and maybe try a different USB port.
Sm-usb 007 device unplugged
hi, the 64 bit driver may be the issue , somehow it's not correctly installed or using a 32bit driver, remove step back on system restore so there's no trace of the installed driver, or un-install however there may be some entries in the registry left behind... okay reboot.... just plug in the device. Does Win7 install a driver ?? I had a issue with similar hardware in Win 8 however it did solve it and it's working now..
Goodluck
Rob.
www.gewizpc.co.uk
Jan 08, 2014 | DekCell EasyCap USB 20 Video Capture...
Atek joystick
If you mean when you crash get shot The joystick vibrates.
The screen is mapped and sends signal to joystick to vibrate.
Oct 15, 2013 | Computers & Internet
IS QUANTUM USB GAMEPAD QHM 7468-2V COMPATIBLE WITH WINDOWS VISTA INSTALLED 2 YEARS AGO
plzzz brother help me, i have the same contrller and i have lost the driver CD... can u please mail me the driver CD on my email address.. see if u can Zip the copy of the CD and mail me on my email. access2avi@gmail.com
Sep 13, 2010 | IGN Entertainment (G60306A) Game Pad
I have a Twin USB Vibration Gamepad i need the driver for Windows 7
there is no driver for windows 7 as sitek (the chinese manufacturer of the device that sells it as in "white box license" for others to print its logo on discontinued such a device since 2005. Mind you sitek.com itself has vanished and a new firm has taken over that address.
Thus end of story , problem on relaying on a small time manufacturor , however i do have the xp drivers and they do work , windows 7 would not accept them and insists that the generic driver it uses is up to date (which works fine except the vibration a.k.a force-feed-back wont work)
I am working on a new uproach on injecting the xp driver into windows 7 registry and if it works i'll let you know :)
Mar 05, 2010 | Genius G-12U Vibration, USB, PC gamepad....
USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
Aug 13, 2009 | Logitech Rumblepad 2 Game Pad
Trying to install Gravis Eliminator Gamepad Pro/USB under Windows XP SP3. When i plug it into a USB port, I get the Windows message "USB Device Not Recognized". If I go to Control Panel > Game...
I have encountered a similar issue before. What works, is to try the update of your chipset's driver. This could be an error once present in your chipset's initial release, but has since then been fixed by your chipset's manufacturer. Also this could another among the millions of peculiarities in the windows operating system, i say this for it is very possible the the controller will function well if a game is started while the controller is already plugged in. Just see if it works, but an amendment to the chipset's instruction set would be optimal.
Jul 20, 2009 | Gravis Eliminator GamePad Pro Game Pad
Vista driver for usb gamepad Gigatech
You can either try and force install the XP driver of this device, or you can manually set the device up as an unknown gaming device.
Mar 05, 2009 | eMachines eMD620-5133 Notebook
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Computers & Internet Logo
1,599 people viewed this question
David Payne
David Payne
