Question about Keurig Platinum B70 Coffee Maker
How does the outer shell come apart - Keurig Platinum B70 Coffee Maker
  • 345 Answers
Here is a link to a manual with trouble shooting tips. to download you do not have to enter email just the numbers information because i did it that way.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
With this link you have option to email the support or just call them and also knowledge base.
http://www.keurig.com/customer-service
Hope this helps.
Posted on Mar 31, 2011
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
It get hot then turn off i got a fan for it
if ps3 is out warranty i recommend taking it out of the outer black shell so it can get proper ventilation . you tube has many great videos for taking aparts ps3.
Mar 06, 2010 | Sony Playstation 3 (PS3) Console
Is it possible take the metal cover off the subwoofer speaker?
yeah, but its glued together pretty well, you will end up pretty much destroying the outer shell trying to get it apart
Mar 03, 2010 | Logitech X-230 Computer Speakers
The bearing on the drum has gone, does it come out from the back after removing the pully?
Reading this to mean the front load laundry design. As a rule it is a complete dis-assembly of the inner basket from the outer shell. There are two halves to the outer shell, you will see all the clips holding them together if you remove the top and look at it.
After disassembling the bearings will drive right out with a punch however, you can usually only buy the half with the bearings and seal(will need this also) as a assembly, and also is over-sized shipping There are two bearings and the seal, it is usually the one further in, not closest to the pulley that goes bad, because the seal is going. You basically have to take the whole machine apart.....
Hope this helps.
Feb 28, 2010 | Washing Machines
AKG Model C451 EB Microphone.
I drilled a tiny hole (.038") through the outer shell and the cartdrige where the body of the XLR connector is mounted and screwed a tiny screw into it from a pair of old glasses.
Sep 29, 2008 | AKG (WMS40DIV444US54) Microphone
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
Aug 11, 2008 | Washing Machines
Khms155lss1
The handle can only be changed by separating the outer and inner shells of the door. You can pull the outer shell off the inner shell by removing the three screws at the end of the door and then using firm force to pull the shells apart. It helps to gently pry along the bottom, top and inside (nearest the hinges) with a thin flathead screwdriver or other very thin metal object. You don't have to get it all the way loose; just a little is fine. You can then use the two clasps on the back of the door (that hold it shut when it's closed) to pull with. I found that inserting a slim screwdriver into the lower clasp and using that as a handle (not a lever!) gives you a better grip. Hold the outer shell of the door with your left hand while pulling the inner shell in the opposite direction. Be carefull not to twist or bend the clasps; they are plastic and will break. The shells will pull apart and then you can access the screws that hold the handle. Change the handle then press the door shells back together. Make sure they are snug all around. Replace the three end screws and you're done.
Jan 08, 2008 | GE JVM1650 1000 Watts Microwave Oven
Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Jul 04, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
Keurig Platinum B70 Coffee Maker Logo
35 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
