Question about GE 29487GE2 Corded Phone
What does 3-beep signal mean? - GE 29487GE2 Corded Phone
Long beep
Beep Codes
Beep signal Additional indicators Meaning continuous beep
  • System board failure
Jan 30, 2013 | Matsonic MS9337c Motherboard
Lots of beeps on startup of HP Pavilion DV6000 entertainment pc
Beep Codes
one long, two short beeps
  • Video adapter problem
  • LCD assembly failure
Jul 07, 2012 | Computers & Internet
I am currently on my laptop because when I turn on my desktop, the monitor (ViewSonic VX2235wm) powers on with a message that says No Signal Digital and then turns off. Any suggestions?
hi; your monitor has no problem, its your cpu. Try to hook your monitor to your laptop,and change the display setting to your LCD monitor. If LCD has displaying no signal mean signal coming form the Video card of your CPU try to visualize if you hearing some beeps into from CPU, some motherboard has beep codes if there's an error or failure to your CPU, 1 beep means its good system test. if you don't hear any beeps, try to check first your Video Card marmeto12_21.jpg if you have Spare try to replace it, try to reset all the connectors even Memory card to its slot. reset means pull the connectors and place it back again, also check the power supply of cpu if still functioning good.but you can test it by multi volt meter. if nothing happens check your motherboard most common failure is bloating capacitor, and overheating chipset. thanks....................hope this helps...................
Sep 07, 2011 | ViewSonic VX2235wm LCD Monitor
The PC powers up, then starts beeping, one long beep and one short beep. The monitor tries to come on but shows the DVI with no signal; and the HDMI with no signal and the VGA with no signal and then the...
the beeps codes means there is a problem with a piece of hardware (RAM, or graphics card ,etc)
I need to know the BIOS manufacturer to interpret the code (phoenix or award or AMI)
for COMPAQ it means BIOS error --and will have to reload it from a recovery cd.
for IBM it means system board failure-- need new mobo--for a beep code of 1 long and 2 short most all mean graphics card problem.
If this was helpful, please indicate so, if not , comment back so we can resolve this issue
Dec 27, 2010 | HP Computers & Internet
When I turn on my pc it beeps three times and there is no signal to the monitor. What do the beeps mean?
hi,
please write your beep description
ex: one long beep two short beep
repeating short beep
Sep 11, 2010 | Gateway 838GM (RB838GM) PC Desktop
When booting the screen says no signal and the it begins beeping intermedately
I think the graphics card has become unseated as the PC does not need a monitor to start up so there would be no beeps; Here is a list of beep codes with there meanings.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Apr 19, 2010 | Gateway Profile 5.5 PC Desktop
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
What does 4 beeps mean on startup?
here is a link to all the beep codes this should help you
http://www.computerhope.com/beep.htm
hope that is ok
Feb 10, 2010 | Compaq Computers & Internet
No signal to monitor / Beeping
Listen to the pattern of beeps, or look at the back of the computer to see the pattern of the diagnostic lights ( 4 lights just under the keyboard/mouse connectors) and check out this site to see what they mean:
Beep Code Meanings
Diagnostic Light Meanings
May 29, 2009 | Dell OptiPlex 160L (160LMIN) PC Desktop
GE 29487GE2 Corded Phone Logo
26 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
