Question about Baby Care
The screen keeps saying VOX MUTE/NO LINK. and i set it up just the directions, said everything is plugged in.
Why radio does not work with headset plugged in
Well there are a few possiblilities:
1 - If the headset is not an OEM part then the wiring or jack may not match or the impedances may be mismatched.
2 - When you say doesn't work you need to be more specific.
VOX capable y/n, VOX Working y/n, PTT on head set y/n, etc.
3 - Has the radio phone/mic jacks ever been modified?
Good Luck with the testing
Jun 22, 2014 | Motorola Mag One BPR40 Two Way Radio
Microphone setting
The face is an indicator for VOX, voice activation. If you are using an audio device (headset or earpiece) with the radio that is VOX capable, this icon will appear. General rule of thumb, make certain the radio is turned off when plugging in any audio device. Plug in firmly, you will feel a slight click when the plug is fully seated. To turn off VOX while you have an audio device plugged in simply press the PTT on the radio.
Here is a link to the user guide for more info concerning VOX. It begins on page 22. http://www.pager.net/LRSimages/PDFs/cls_series_userguide.pdf
Best regards.
Feb 23, 2013 | Motorola CLS1110 Professional 2-Way Radio...
How do you disable the VOX setting on a Talkabout MR350 2 way radios. I wan to use it with a headset, but do not want VOX on.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf You will find the instructions for VOX and iVOX on the bottom of page one, and at the beginning of page 2.
Be certain when plugging in your audio accessory that the radio is turned off. If the radio is left on inadvertently, you would have no control over the VOX settings, it would immediately be in a confused VOX mode.
Also, with most Motorola radios, if VOX begins to occur, turn off the radio, and then re-insert the audio device plug. And in some instances, pressing the PTT on the radio when you are having a VOX occurrence will put the radio back to push-to-talk status.
Best regards.
Feb 19, 2011 | Radio Communications
I cant turn the vox off of the radio. i plug in the headset and it locks the keys and i cant hear anyone talking to me through the headset.
Only plug the headset in with the radio turned off, and be certain to use a headset designed for the radio. On the SX model radios the VOX or iVOX feature is automatically set to the last sensitivity setting when you plug in an audio device. Here is a link to the user guide, where you can read how to turn iVOX and/or VOX on or off.
http://www.giantintl.com/ContentManage/manuals/Moto/SX700.pdf
Best regards.
Nov 01, 2010 | Motorola SX600R Two Way Radio
I am having trouble programing VOX to work on motorola rdu 2020 2-way radios
Here is a link to the user guide: http://www.twowayradiosfor.com/pdf/RDX-Non-Display-manual.pdf
Instructions for setting the VOX sensitivity are on page 33.
According to the manual you program the VOX using the CPS (software). Three things which usually cause end-user problems are:
1) Failing to set the sensitivity to a number 1, 2, or 3.
2) Failing to have the radio shut off when plugging in the audio device (headset or earpiece)
3) Failing to use a VOX capable audio device. (Not all headsets and earpieces are VOX capable. Many with inline PTTs are not.)
If these items or instructions do not help, stop by your local Motorola dealer to discuss the problem.
Best regards.
Sep 22, 2010 | Motorola RDU2020 Two Way Radio
I have a Motorola MPB30 video baby monitor and it has developed a fault where it goes into sleep mode after a couple of minutes even though it's fully charged. An on-screen message has also appeared at the...
That's not a fault - that's the way it works in VOX mode. VOX means it only plays when it hears a sound on the camera end, and goes into a lower-power standby mode when nothing is happening.
Turn off the VOX (Menu -> picture of a guy talking -> turn all the way down) to have it constantly transmit.
Personally, my wife and I like the VOX all the way up. It keeps us from having to check at every peep and squawk, but does let us know when crying is going on.
Jul 28, 2010 | Toys
Vox External Hard Drive - Unknown Device???
My drive will do that if the external power to the drice isn't working.
Mar 14, 2010 | RPM Vox 750GB 3.5in USB 2.0 & eSATA...
Tape stops
There is a switch on the right-hand side of the machine labelled 'VOX'. Set this switch to the 'OFF' position and you should be good to go.
'VOX' is voice-activated recording. It's designed to record only when someone is talking, and to pause when nothing is being said. In theory it's a great feature, but it never really works as good as you'd like. It'll usually miss the first few words you say, or it'll cut in & out while you're talking.
You can also set the 'VOX' sensitivity by adjusting the 'Tone/VOX' slider on the front of the machine.
Hope this helps...
Aug 13, 2009 | Dictaphone Audio Players & Recorders
Motorola T5622 VOX Not Activating with Autocom Sys I have an Autocom (Kit 300) motorbike coms system. I bought the accessory cord that interfaces to the Motorola T5622, for VOX I have followed the Motorola...
Hi Folks, two seperate checks to do - to check vox on autocom and transmit on motorola. With the T5622 unconnected to anything, does the push transmit button work - e.g. does it make the beep noise at the end of transmission?
Does your autocom work with any other sound sources - i.e. mp3 player so you can hear music. Does this mute when you speak ? (it should if vox is working). Note that in this setup vox is provided by autocom - NOT BY THE T5622. The instructions you mention are for the motorola vox kit.
Wire the two together and you should get the motorola beeping through your autocom at the end of transmit - that's what my kit 200 does with my T5622.
Mar 13, 2008 | Motorola Talkabout T6310 (14 Channels)...
Earbuds
If you are using vox (voice activated transmit) go into the menu and make sure you don't have the VOX setting too high. You should be able to put the headset on... hit the "push to talk" button on the radio and transmit you audio. Turn the other radio on and make sure the radio is "keying" (tx with no auio) then make sure there is audio. If you don't have audio but the radio is transmitting.. you might have the wrong type of plug on your headset for the audio..... there are 2 plugs... 1 for transmit audio....1 for recieve audio. It could be the wrong type of plug for the jack in the radio. Regardless.. the way the headset works is either you push the "push to talk button" onj the radio OR you use the VOX function... with the vox function you just have to talk into the mic to transmit. This is what your headset is designed for. You will have to go into the menu and set up the radio for VOX. If you still have problems follow my directions at the top of this page ( check mic jack and stuff) I think you just have to set the radio up for VOX operation and set the VOX setting. You should be able to push the push to talk button and talk through the mic on the headset. If you don't get any audio that way there is a problem and you should check the jack and plug on the headset.
Aug 25, 2007 | Motorola Talkabout T5720 (7 Channels)...
Baby Care Logo
Top Baby Care Experts
masud
masud
Tom Chichester
Bill Boyd
Are you a Baby Care Expert? Answer questions, earn points and help others
