Question about Garden
We need a manuel for the curve o mark tool - Garden
  • 2,510 Answers
These are the only instructions in the box, the other side of the sheet is a kist of their other products.
INSTRUCTION SHEET
Centering Heads
Curv-O-Mark Centering Heads aid in the setting of centerlines, establishing angles and marks for ****-ins, locating points inside pipes and tanks, laying out keyways and measuring declivity. The standard model (Stock No. 6) is used on pipe 1/2 inch diameter and larger. It has a 4 inch Y-type head and is fitted with an adjustable dial bubble protractor and a manually operated hardened centering pin.
The jumbo centering head (Stock No. 7) is for pipe 1 inch diameter and up. It has an 8 inch Y-type head and an adjustable dial bubble protractor. A spring-loaded hardened centering pin eliminates the need for a hammer.
To quickly and accurately locate the center point on a pipe, shaft or other cylindrical surface, first set the protractor dial at zero (0). Then place the centering head in the vicinity of the highest point of the cylindrical surface.
Move the centering head across the surface until the bubble is centered, then strike the centering pin a light blow. (On the jumbo model, release the spring loaded pin.) The resulting indentation will be top dead center.
If the desired center is at some angle away from top dead center, merely set the protractor dial to the appropriate degree mark to the right or left of zero (0); and then move the centering head around until the bubble is centered. At that point, make the indentation.
The centering pin should be used only in conjunction with the centering head. It should not be used as a center punch. Avoid making unnecessarily hard blows to the pin with a hammer or other objects.
No. 6 Standard Centering Head 0721-0005
No. 7 Jumbo Centering Head 0721-0006
Form 806 R 5-89
Posted on Mar 31, 2011
Hello my name is manuel if I can help with my problem is that my car saturn L200 2003 the scoreboard does not work me all symbols mark the mark I either gasoline speed revolutions per minute and the light...
may be you should make a diagnostic and you can do it in a garage or you can do it by yourself if you want to do it by yourself you need some tools and you can find some good ones here: spobd2.com
Apr 08, 2013 | Saturn Cars & Trucks
Every time that I put in a function such as Y1=(square root symbol)100-x^2) Y2= -Y1 and both functions are highlighted at the equal signs, but after I hit trace it will only do Y1. I have experimented and...
You can draw several graphs on the same screen and use the TRACE function to move the cursor along a curve and read the values of the x-y coordinates. To move cursor along the same curve you use the left and right arrow keys.
But to jump from one curve to another curve, you use the Up and down arrows. Each time you press the Up or down arrow cursor jumps from the current curve being traced to the next one as they were entered in Y= editor.
Nov 09, 2010 | Texas Instruments TI-84 Plus Calculator
Blackberry Curve 8310- What is the white sticker
this is a moisture detector. when the battery is exposed to water, the red 'x' will bleed off and make the sticker appear pink.
Jul 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
I need to curb the text kind of like word art in corel x4 can you help me to do it or how to do it
To create curved text you need to use the text tool and fit to path. When you create a shape, line or curve and then select the text tool you can make the text take the same path as the object you created by just hovering it over the objects outline, you should see the courser change.
1- Draw the a curve
2- Select the text tool and hover it over the curve that you created and then when the course changes click on the line activating the text tool
3- Type the text
4- Select the curve and change the outlone color to transparent
Jun 10, 2009 | CorelDRAW Graphics Suite X4 for PC...
Replacement user manuel
sir you can not get mannual and disk because when we buy phone it comes with phone
Jun 01, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Green shadows and curved picture
the convergence apms ic"s need to be replaced
Aug 16, 2007 | JVC AV-65WP74 Rear Projection Television
Garden Logo
295 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
