Question about Refrigerators
How to replace a defrost heater on a ge side by side
  • 132 Answers
The auto defrost cycle uses 4 components. A timer, a defrost heater, a defrost termination switch and a fusible link.
Any one of those could stop your fridge from defrosting.
The best thing to do is do a diagnostic on the defrost components to work out which component is actually faulty.
Posted on Apr 01, 2011
My GE model GSH25KGMB BB side by side refrigerator is not cooling on fresh food side. Freezer and ice maker side working fine. How should I troubleshoot this?
On your model I would go straight to the defrost heater and defrost thermostat and check them first after defrosting the evaporator first with a hair drier. Both parts need to be replaced=> WR51X10055 Defrost Heater Assembly 25953576-emtx2i4tcmlh0qfjbwwrn2z1-2-0.jpg and the=> WR50X10068 Defrost Thermostat APPLIANCE 911
Nov 11, 2015 | GE Refrigerators
I replaced defrost heaters and defrost contoller on GE TFH22PR and the heaters still don't work. One of the old heaters actually shorted out - is it likely the oveload needs to be replaced too? is there...
There are only 3 parts to the defrost " system " . The defrost timer , defrost bimetal ( the 1 inch cylinder piece clipped to the top of the coils , with 2 wires going to it ) and the heaters .I do not know what you are refering to , as the " controller " . You have replace 2 out of 3 , so replace the third , which is probably the problem .
Sep 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Top section not cooling on GE Side by Side
IF the evaporator is frozen then the defrost is not occuring. Probably the heater or the defrost thermostat.
Sep 10, 2009 | GE GSH22JFT Side by Side Refrigerator
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice building up in freezer
Due to the frosting up, The glass defrost heater broke. Any good tech knows this happens. The defrost heater must be replaced. If this is a GE side by side. The new replacement heater has dual elements. The standard heater that was put in them, was not large enough to defrost the coils fully. Replace heater and you should be fixed up. I would also replace the thermostat while you are in the freezer section they are only like 15 bucks and this way you will have a new defrost circuit.
Jun 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE fridge is not defrosting the coils in the back. What's up?
if u have frost build up in the freezer it will affect the temperature
and it needs to defrost
problems could be
defrost timer.
thermostat.
terminator.
heater s.
unit problems (unlikely) if even frost coating.
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model tfx24f defrost not working.
Replace the defrost heater and defrost thermostat located behind the freezer panel inside the freezer compartment.
Jun 12, 2009 | GE PSC23NHN Side by Side Refrigerator
GE side by side GSS20IEP Refrigerator freezer freezing
this is a problem that is no stranger to most GE side by sides; GE has used a glass type defrost heater in the freezer which often fails. If you manually defrost your appliance (unplug and leave doors open for 24 hrs) then plug back in, it will appear to work normally for a few days and gradually build up frost on the evap panel (back panel in the freezer) and eventually the refrigerator side will seem to loose cooling due to frosted damper, or lack of cold air transfer over the evap coil. The fix for this is to replace the defrost heaters (s). While not as common, defrost thermostats can open causing the unit to skip defrost, and even less likely is the defrost control (either mechanical timer or adaptive defrost). First, defrost your appliance, then remove the evap panel and ohm out the heater(s), if open, replace. If they check ok, check your defrost thermostat (small disc like object attached by a clip on the evap. coil itself) for signs of popping open or open ohm readings at normally closed temperatures. Its a good idea to change this anyway when replacing defrost heaters as the two work hand in hand. Last, check the defrost timer by manually advancing the screw advance clockwise until you hear the first click, then check voltage to the defrost heater and thermostat, if no voltage present replace timer. If your appliance is equipped with a adaptive defrost board, refer to the schematic for proper diagnostics.
Jun 11, 2009 | GE GSS20IEP Side by Side Refrigerator
GE refrigerator gsl25xgwss defrost problem
Either heater or Board is most likely bad. You can remove heater and test it with ohm meter for continuity
Oct 05, 2017 | GE GSL25XGWSS Stainless Steel Side by Side...
I have to keep defrosting
it may be the heater safety cutout stat that has stuck open
Aug 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Open Questions:
Refrigerators Logo
106 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
