Question about Vehicle Parts & Accessories
I have a nissan quest 2004. it has an intermitent problem with the interior light system. the light goes off and stay like that for quite some time. when i less expect i start working again. when shut the care down and re-start it the light does not work. this is crazy. see if u can help. thanks:pedritof
  • pedritof Apr 01, 2011
    I checked the fuse and all the bulbs are ok. i dont think its a fuse problem. We dont know when they will turn on again currently they are off. You never know when its going to be on or working properly.
    any other suggestions and could it be a problem with the alarm system malfunction. i know it has something to do with the alarm.
    hi,darklord1! Don't you think if one of the door's switch is shorten the light is supposed to fail from that door in particular and not from all the doors? isn't the light supposed to work when i turn it on from the main switch inside the cabin, even with the doors closed? remember they don't work in either cases.
    it sound more like a relay problem. do you know were that relay is located? i don't understand what the hood light switch you mention is located. can u explain a little bit more about it? can you send some type of illustration? thanks:pedritof
  • 2,427 Answers
No it cant be the alarm system malfunctioning as it would have disable the car. Its not a fues else the problem would be persist.
This leaves 2 things.
The relay,
The switch (hood and door sensor).
I'm leaning towards the switch shorting out. There are 5 switches, 1 on the hood light, and the other on the doors. open your driver door and look at the side of the car where the door closes it looks like this
they are on all four doors, one of them is shorting out, open each door one at a time, ignition on, the lights should come on , if not, press and release the switchs rapidly until you find the one that turns the light on, Try cleaning he switch and if not, replace it.
In the mean time, set your hood light switch , from door to on or off , to make sure everything else is fine, Once the setting is on door and the switch is shorting you will have the problem.
Posted on Apr 01, 2011
  • Rishi Roshan Ali Apr 01, 2011
    not really, each door switch are actually 2 switch's, 1 for that door and the other for the hood light. do if 1 point of contact is bad the other one still works fine. The relay is located in the fuse box under the hood. There is a diagram on the cover showing which relay is which.
    Genius:
  • 1,622 Answers
HI, You have an issue with fuse problem or bulb. you will need find where the fuse box is inside the engine, by opening up the bonnet of the car, and locate where the fuse for bulbs are,and see if the fuse is still working, you can use a meter to read the fuse.might also be that the bulb is not placed properly or the fuse is shaking.
And also before you check for the fuse inside the bonnet,you will need to test the bulb also that is switching off if it's still ok,or needs to be replaced..
If you can do it your self,i would advise that you call an expert on this, handily issues with wiring in cars are funny sometimes.
Do a general troubleshooting .
Good luck.
Posted on Mar 31, 2011
2004 Nissan Quest hatch door opens then reaches the top and starts bucking violently and then goes back down ( it does not stay open ) please help
Probly a motor or module issue. Take out the fuse if its not connectd to other systems. Or unplug wiring to mechanism..may need to unscrew hatch panels. Openin it by hand can save$and headache
Sep 07, 2015 | 2004 Nissan Quest
How do I prevent the interior lights from coming on when driver's door is open - disable the sensor on the driver's door -- 1999 Nissan Quest.
Can you tape a coin or two onto the door at the spot that hits the light switch? If not, just remove the bulbs.
Dec 09, 2014 | 1999 Nissan Quest
2004 nissan quest stay running
you can have various problem. see the diagram attached. Crank sensor, PCM+BCM, sparkplug+wirespark+distributor.
Please RUN the scanner/*computer for easy diagnostic and fix it.Remember the electronic vehicle is very complicated Now
Jul 21, 2013 | 2004 Nissan Quest
Stay running after starting
Try cleaning the throttle body
CRC Throttle Body Cleaner
Instructions on the can
2008 Nissan Quest Reverse Park aid stoped working. First sound got funny and then quit. The switch disable light stays on and won't turn back on
replace the beeper that makes the sound when you are in reverse.the light will also go out after you replace thet beeper.
Sep 16, 2012 | 2008 Nissan Quest
All interior dome light are out on 2004 quest, fuse checked are good
The interior light are controlled by the Body Control Module (BCM).
Check the fuse for the BCM. If the fuse is OK, then try to disconnect the car battery for about 10 minutes to reset the BCM. If resetting the BCM doesn't work you may have to replaced it.
Jun 23, 2011 | 2004 Nissan Quest
All the running lights on a 2004 nissan quest went out at the same time. The a/c and radio lights went out too but don't know if it was the same time as the running lights. Is this a problem with the fuse?...
A light turn on my quest 2004 I don't what light his by the abs and battery light can some one please tell me what light is it please thank you
Aug 17, 2010 | 2004 Nissan Quest
Battery drains in my 2004 Nissan Quest
I have the same problem on my 2004 Nissan quest, and the battery will die if i do not drive it for 3-4 days, i have replace a ACdelco ACD24F60 new battery and it has the same problem too. I just get a Nascar advantage charger Model 11-1577-6 from Canadian tire, and try to recharge it but the LED flash after few hour, I set to normal battery type, any idea how to fix this problem. thanks.
Feb 12, 2010 | 2004 Nissan Quest
Personal Lights in a 2004 Nissan Quest won't turn on
have the courtesy light circuit tested, u may have a sticking switch..
Jun 03, 2009 | 2004 Nissan Quest
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
