Question about Craftsman 22" Rear Bag Rear Propelled High Wheel Lawn Mower ()
My Craftsman mower starter cord has wound back to the mower...is there a way to free it myself or is this a "shop" fix?
    Novelist:
  • 111 Answers
You should be able to do this yourself. You will need the following: A phillips head screwdriver, Socket set in SAE, and a short 3" extension for your socket driver, replacement rope, and the handle. First, take off the plastic cover for the top of the engine. You will use the phillips head screwdriver. Take the cover off and set it aside with the two screws inside of it or in a safe location. Second, you will use a 5/16 socket to loosen the screws that hold the fuel tank in place on the flywheel housing, once it is loose pull it back and out of the way. CAUTION: the fuel line may come off and you may leak some fuel out of the fuel tank. Third, you will need to take the 5/16 socket and remove the screw that holds the dipstick to the flywheel housing. Then take the dipstick up and turn it around so it is 180 degrees from where it was attached to the flywheel housing. Fourth, Take the bolts out that hold the flywheel housing to the engine. You will use a 3/8 socket on these bolts. There are two bolts on the front of the engine (close to the spark plug) and two at the back of the engine (these were covered by the fuel tank). Once the bolts are out of the engine, you should be able to pull up on the flywheel housing and it will come off of the engine. Fifth, remove any of the old cord from the rewind pulley. Put one end of the NEW rope through the eyelet on the top of the rewind starter and push it through the hole in the pulley. Tie a secure knot to make sure the new rope does not get pulled free of the rewind starter. Depending on the type of plastic cover on top of the flywheel housing you may need to put the rope through the plastic cover before attaching the handle to the other end of the rope. Attach the handle to the other end of the rope with another secure knot. The video will describe how to put tension on the rope. Assembly is a reverse of the dis assembly.
Posted on Apr 01, 2011
Rewind starter cord
How To: Rewind a Recoil Rope (Fix a Broken ... - YouTube
? 2:52
https://www.youtube.com/watch?v=J0KJuqsJJ_k
Feb 16, 2012 - Uploaded by Champion Power Equipment
How To: Rewind a Recoil Rope (Fix a Broken Recoil Rope) .... Back off until rope hole in pulley lines up ...
How to Repair a Small Engine Recoil Starter - YouTube
? 4:49
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jul 15, 2011 - Uploaded by eReplacementParts.com
How to Repair a Small Engine Recoil Starter ... Would like to now use the pull cord on the mower but it won ...
Nov 28, 2015 | Garden
Did a Tune-up, now the Starter just Free Spins, Bendix not engaging, How to Fix, without Replacing Starter?
Try the starter off the mower to see if the bendix works. See if there is any adjustment at the starter mount, play in the mounting holes.
Aug 29, 2015 | Craftsman Garden
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
May 10, 2014 | Craftsman Garden
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
How do I change the pull starter cord?
If this is like most simple mowers (using briggs & stratton engines and some others) the recoil starter is in an assembly which is spot welded onto a metal cover. You may have to first remove a plastic shroud (which might include the gas tank - which should have a shut-off valve). Then you should be able to remove the metal cover that includes the recoil starter. When you get that off you will see a plastic spool that holds the cord. This spool is probably held in place by a couple of metal tabs that are bent down. Bend those tabs up with pliers. Underneath the spool is a spiral spring that provides the recoil. Take careful note of how this all goes together. Buy a new cord (available by the foot at a hardware store) and wrap it around the plastic spool. Use a piece of tape to hold the end of the new cord above the spool so you can thread it through the hole in the metal housing later. Put the spring and the spool in place, then wind the spool to put tension on the spring - about 5 turns in the direction that would push the string out through the hole. Once you have the spring "wound up" remove the tape and thread the end of the cord through the hole. Now bend those metal tabs back down. Put the handle on the cord end (or tie a knot) to keep the spring from pulling the end of the cord back through the hole. Reassemble the rest and you are in business.
Jun 28, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
The pull string will not pull out to start the
Remove the starter mechanism from the saw and try to turn the flywheel--it should turn freely except when the piston is rising against compression. If ok, pull the starter cord and watch for twisted cord or a damaged/split spool. Try to turn the spool CW by hand to see if it is bound up by something. Was the starter cord just replaced? If so, maybe the return spring was over-wound and can't be turned further. Hope this helps!
May 21, 2010 | Craftsman Garden
Lawn mower troubles
You must first remove the cover assembly which houses the starter pulley. Pull the old rope completely out until it no longer moves. Hold the starter pulley and remove the old rope. Try to wind the starter pulley spring tighter if possible. DON'T LET GO. The starter rewind spring must be wound before installing the new rope. After winding the spring, thread the new rope through the cover and into the hole in the pulley. Tie a good knot in the end and let the rope wind slowly into the housing. Once you have this done, replace the cover, get the proper length of rope, thread it through the handle, tie a knot in this end and your ready to go.
May 19, 2009 | Mtd 22" Yard Machine Push Mower
Open Questions:
Does the belt slip going uphill or with a full grass bag? My Craftsman mower lost the self propel feature. The small pulley on the top of the transmission would slip under load, There was just not enough tension on the belt to over come it. Tried a new belt and also replaced the tensioner spring...still slipping when going uphill or with full bag. Possible pulleys worn...not wanting to gamble more time and labor, I bought a 4" 1/4" cap screw with extra nuts and flat washers, a 3"16 eye bolt as well. Drill a 1/4" hole in the bracket that holds the trans activation cable in place and a 3/16" hole in the mower deck so the holes are in alignment with each other. Put the cap screw through the 1/4" hole with the threads facing toward the front of the mower. Fasten the eye bolt into the 3/16" hole in the mower deck locking it in place with one nut on each side of the metal. Now you have the 1/4" bole protruding through the eye bolt. Using a flat washer and nut, tighten then nut easily and when there is room put a second nut on it. When you have tightened it up to the desired belt tension lock the two nuts together using two wrenches. Note...do NOT make the belt incredibly tight or you will destroy the trans in a short time. Go a little at a time till the drive does not slip under load. Good luck hope this helps. Oh....you will have to trim the plastic cover that covers the transmission so the added bolt will clear it and you can put the cover back in it's proper place.
Mar 01, 2017 | Craftsman 22" Rear Bag Rear Propelled High...
See all Craftsman 22" Rear Bag Rear Propelled High Wheel Questions
Craftsman 22" Rear Bag Rear Propelled High Wheel Lawn Mower () Logo
292 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
