Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE model # GSS25JFPHWW looking for the defrost timer on this one is it behind the ice maker in the freezer
  • 1,543 Answers
Defrost is controlled by the mother board, behind small rectangular panel on back of refrigerator. Part # WR55X10942 . (you can not use the board to manually defrost) If you are having a defrost problem, the most likely cause is the defrost heater (WR51X10055) and while you're at it, you might as well replace the defrost thermistor (WR55X10025) located at the top of the cooling coils. Manually defrost freezer by unloading freezer, removing shelves, and removing back panel inside freezer, then use hair dryer to melt frost. (you have to take those parts off anyway to get at the heater and thermistor)
Posted on Mar 31, 2011
Replace deforst timer in ger gsh25jsxb
There is no defrost timer on a GSH25JSXBSS Can you provide an actual freezer temperature? Feel the base of your ice maker to see if possibly the heating element is staying on after dropping the ice into the ice bin and look for the ice maker to see if excess water is flowing into ice bin once it refills. Are other items defrosting in the freezer due to extended defrost? I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE GSH25JFR Side by Side Refrigerator
Ic6 ice maker
Some models like yours came with a defrost control board and others came with a defrost timer. They should be found inside the fresh food compartment and behind the temperature control panel. You will need to inspect and let me know which you have. Unplug first. If the control board looks or does not look burned it could be bad. The timer can be turned clockwise until compressor stops and should remain stopped for about 25 minutes. and then turn itself back on. If these look good then we need to remove the rear panel inside the freezer and test the defrost element with one wire disconnected to check for continuity. Just to be sure the element has not burned out. The defrost thermostat is connected to the defrost element and will have open contacts inside it above 50 degrees.
Jul 16, 2013 | Amana Easy Reach AFD2535DE Bottom Freezer...
GE GSL22JFTABS Frost buildup on back wall of freezer and ice maker not making ice
Your unit is not defrosting, causing the unit to build up ice and not allow the air to flow. There are 3 possibilities, listed with the most likely first.
1. The DEFROST HEATER in the freezer section, just behind the cover along the back wall of the freezer.
2.The DEFROST BI-METAL which is just about the HEATER, it is a small round thermostat that keeps the HEATER from getting too hot
3. If both of those parts are good, then you have a bad MAIN BOARD. The board regulates the defrost cycle, which replaced the older defrost timers.
May 20, 2012 | GE Refrigerators
My ge side by side refrig freezer gets on the auto defrost cycle in the freezer and then all the ice cubes in the ice maker freeze into a solid ball of ice. The ice maker does not work after that. Why does...
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Nov 02, 2010 | GE Refrigerators
My GE GSH25JFTC side by side freezer/refrigerator has ice accumlating in the area around the ice maker both above and below the ice maker and in the door shelves in vicinity of the ice maker. It's three...
DEFROST PROBLEM The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad. With an ohm meter it should show continuity when cold and none when warm. You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others. You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Sep 11, 2010 | GE GSH25JFT
Side by side refrigerator the refrigerator does not get cold but freeze works fine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Jan 01, 2010 | GE GSS25JFM Side by Side Refrigerator
I have a GE Model #GSL25JFPABS fridge. My freezer has been frosting up for quite some time with the ice cubes melting a bit and freezing together. Recently the fridge side has also been warming once in a...
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 29, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Need help finding the defrost timer in GE fridge !!
frigidaire Model frs22zrg Water leaking into the the dispenser (where you put the glass. Also the ice dispenser become iced and where the ice comes out.
The moisture is inside of the freezer part, may need a time or the heating coil is not working.
Aug 08, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Ice maker not working freezer temperature at 31
The ice maker isn't working because the temp needs to be at least down to 10 degrees. The fridge side should also be warmer than normal. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
If it's not a defrost problem make sure the fan in the freezer and behind the unit next to the comrpessor.
How to check stuff>
Jul 11, 2009 | Samsung RB215LASH
Defrost Timer
Hi: It is your defrost heater most likely. If not the defrost timer. The heater is in the bottom of your freezer behind the metal panel. Next time you defrost it remove the panel and inspect it. It's a glass tube with a metal coil (filament) running through it. If the coil is broken replace it. If not look into a defrost timer. The parts will be shown on sears.com with a diagram. I hope this helps. Jeff
Jun 08, 2009 | GE GSH25SGPSS Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
667 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
