Question about Sears Genie Garage Door Gpwk12 Wireless Keypad Compatible with 9 or 12 Dip Switch Genie Max Openers
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed by constant pressure on the wall-mount control. I've cleared the remotes and re-programmed them and it still does not close. Any ideas? Thanks, Brad
  • antikbuff Mar 18, 2015
    sounds like the safety lights need adjusting or something is blocking their conection to each other. Try moving everything away from the garage door by a additional 4 inchs.
    Also... the sun could be affecting the reciver lights.
  • 59 Answers
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Posted on Apr 03, 2011
My garage door opener remote does not work.I have a craftsman garage door opener manufactured in 1999. The garage door opener remote panel has a green light on and will open the garage door. The remote,...
Make sure the green light in the wall control is not flashing. That locks out the remote. If it is press and hold for 3 seconds the lock button on the wall control. It could just be that your remote has failed.
Dec 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
My remote for Sears garage door is broken. It is from 1978. I was told that there is no replacement. If I could fix this remote, I would be OK. The setting in one of the cars still works. The remote's...
I would replace the 32 year old opener with a new state of the art model. If that isn't an option you can take a look at the Sears universal remote control replacement kit.
Model #00953751000
Oct 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sears garage door opener (GDO) model 139.53985D, only a couple of years old. 315MHz remote controls. Opener has stopped responding to the remote controls,unless a remote is held wihin 12 inches of the...
There is no way to change that radio frequency it is set by the government. Sears service technicians have an instrument to help them locate the interference that causes this type problem.
Oct 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a crafsman opener #139,53879. Installed an outside remote on door and now the factor opener will not work.
Sounds like your outside remote may be the wrong one for your opener. Program your original remotes and you will most likely find your outside remote will not work. The model number for your opener is on the opposite end of where all those white wires go. Use it whenever you need to buy anything for your opener.
Dec 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote
It sounds like the lock function has been toggled on. Press and hold the button on the wall control with the lock icon for 3 seconds. This will toggle that function off.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to match DIP switchs on a universal garage door remote
I find Clicker products confusing. Might want to buy whole new replacement readio control set. how old is operator?
Jan 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens on it own and light blinks
  • Stuck remote control button. Check all remotes. check LED on receiver.
  • Staples around Multi-Function Control Panel bell wire could be cutting into that wire. Remove wires from opener and test. Replace staples causing intermittent short.
  • Multi-Function Control Panel could have sticking door control push bar. Remove wires from control panel and test. Replace control panel if defective.
Dec 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote Garage Door Openers won't work
Does your wall console have a LOCK or VACATION setting. Turn off.
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Cannot program additional remotes to new door opener
THe old transmitters have a differnt code...more than likely your new one is a riolling code and the old ones are not. They are not interchangeable.
Oct 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Genie Garage Door Gpwk12 Wireless Keypad Compatible with 9 or 12 Dip Switch Genie Max Openers Logo
426 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
