Question about Alpine CDA-9827 CD Player
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
    Scholar:
  • 146 Answers
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Posted on Mar 31, 2011
Lenovo Touch pad Stopped working
If you're positive you didn't unplug or rip anything while installing new USB ports, trying checking/updating or rolling back the drivers for the touch pad. Installing new USB ports could have mis-configured something and disabled or modified your drivers for the touch pad.
Mar 12, 2014 | Lenovo IdeaPad Y550 Notebook
Broke screen
you only have a couple options.. find the same phone with something else broken and buy it cheao and swap the glass.. or pay to have the glass replaced.. try craigslist.. 6_18_2013_6_28_26_am.jpg
Jun 16, 2013 | Lands Phones
Just bought summit s 670 natural gas 89208 grill. Bought a display model because it was the last one they had. It was already assembled, so I took it home as is. Everything works great - except....the...
To determine if it is the switch, remove the wires from the back of the switch and touch them together, if the lights come on, it is the switch. You will have to contact Weber for a new switch.
Jul 17, 2011 | Weber Summit S-670 Gas Grill
PS3 Discs Not Loading.. (Dvds, Cds) We Opened Up The PS3 And Checked The Drive And Cleaned The Lens And Dusted Off Everything Pretty Much And We Put It Back Together And turn it on Still Not Working Jus...
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Dec 31, 2010 | Sony Playstation 3 (PS3) Console
96 skylark gs. all dash lights remain on after 5-6 second delayed ignition start. immediate false start followed by 5-6 seconds turning over then start.everything works electrically and it's driving all my...
Put a test light on the starter ignition terminal,on the starter,if the test light lights up as soon as you turn the key to the start position,and the starter delays starting,check the voltage at the same spot,with a volt meter.If the voltage is lees than 12 volts,and then jumps to the 12 volts,after the delay,then replace the ignition switch.If the voltage is at 12 volts when the key is turned to start the car,and the delay occurs,replace the starter.
Nov 19, 2009 | 1996 Buick Skylark
All the connections work the ps3 comes on but then goes black
You may have messed up the Screen-Settings, to solve this try this.
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
Step 4
: We recommending performing the safe mode options in the following order until one of the options works for you. If one of the options work, do not continue onto the other options.
  1. Restore Default Settings
  2. Restore File System
  3. Rebuild Database
  4. Restore PS3 System (This will wipe your harddrive, so remember to backup savegames.)
Oct 10, 2009 | Sony Playstation 3 (PS3) Console
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
HTC Touch Pro LCD Going black and then sometimes working
is there the "calendar" and "contacts" menu buttons on the bottom of the black screen?
that's what would happen to me. i just turned off the touchFLO 3D on the today screen (by going to settings, then today screen options) and it seems to not go black anymore... even after being untouched for hours.
not sure if the same thing is happening to you, but it worked for me.
Jul 19, 2009 | HTC Touch Pro Smartphone
Turned black
I had the same problem.  I went to the Apple.com site and went to the trouble-shooting section.  They said I needed to "reset" it.  This is done by holding in both the turn on button on the face and the turn off button at the top.  Hold in both at the same time for 10 seconds are more.  That worked for me.
If that doesn't work, they also had something which required hooking it up to your computer, but that "fix" erases everything you have added to it.  It's just like starting over.
Hope the first method works for you.
Mar 19, 2009 | Apple iPod touch
Touch pad keys don't work, except the one to turn phone off
Oh my gosh!!!! It worked!!! It really worked! I had my phone in the back pocket of my jeans when I went outside in a heavy rainstorm to get to my car. When I got to school (I'm a teacher) I realized my phone wouldn't work...except for the power button. None of the other buttons worked at all...AND...GULP....the water indicator sticker inside was red. I got my second graders busy, then looked on here for some help on what to do. I read the comment about how the person laughed, but banged the phone on her knee after reading about banging the phone....not thinking it would work...and it DID! I'm SO happy!!!! Thank you
Mar 18, 2008 | Motorola Mobility RAZR V3
Alpine CDA-9827 CD Player Logo
267 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
