Question about Sony KDF-E50A11E TV
I have a 50ich kdfe50a11e tv the picture is very dark its up to the brightest on the remote and the picture is still very dark what can i do manually to fix this
  • bcn614
    bcn614 Oct 01, 2012
    Hi, same problem here, even with a new lamp. DId you find a solution? Ty in advance
Good evening,
In the command menu and go to the image you put in more contrast, brightness, etc ... this page can control the television picture.
Hope this helps
Lurdes
Posted on Jun 06, 2011
TV powers on, picture blinks once, screen goes dark with green power light remaining on steadily
What is the brand name and model number to your TV? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Televison & Video
Our tv screen is dark on certain channels and if the particular show is showing a night shot on every channel.
Try entering the "picture" sub-menu in your settings, then set the choice on "vivid" (or whatever the brightest setting is). If that doesn't work, try attaching the device on another input. Occasionally, if you are using the coaxial output of your device (the screw-on cable), it can give you a dark picture. If you have another output on the device, try it instead.
Jan 11, 2011 | Televison & Video
My Samsung DLP HD tv's picture is starting to go dim. What can I do to make the picture bright like it used to be. Model Code - HLS6187WX Thank you for any help you can provide. Spencer
Has the lamp ever been replaced? As lamps age they get darker screens. First though check to make sure the TV settings aren't accidentally on a dark setting. Go into the menu and see if increasing the brightness helps.Different picture modes like movie, games, vivid have different brightness settings vivid usually the brightest.
Sep 11, 2010 | Samsung Televison & Video
Tv has picture but it is dark with settings set to brightest settings
First thing to do id replace the lamp. If that doesn't help then the light engine needs replaced.
Dec 09, 2009 | Mitsubishi WD-62531 Projection Television
Monitor grays too dark
That means that the inverter board is faulty and myst be replaced.
The inverter board is an high voltage board that supplies AC power to backlight system. when inverter is faulty, you will get an extremely dark picture.
Parts must be tested before replacement.
Sep 11, 2009 | HP W2338h 23 in. LCD TV
Best settings
Vivid will make the picture look its brightest, press either Status, info or recall on the remote to see what Resolution you are receiving. If 1080i or higher,(720p is higher than 1080i) you should have a very clear and crisp picture.
Aug 09, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
The pic needs to be brighter. we have the adjustment to the brightest setting
If you take the back off the TV you will see the 3 picture tubes. You can clean the lenses. Also there is a mirror mounted to the back..if you clean these it should help. If the picture is really, really dark, then you probably have an electrical component bad in the TV and will need an expert to repair it.
Jul 07, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Dark screen even after setting is at its brightest. Just happened mid game.
did you try restarting it?
hold down the home button and the button at the top until it restarts
May 15, 2009 | Apple iPod touch
Very dark picture on TV
Try restoring all factory settings. On your remote, press the reset button twice. If that doesn't correct it, then you'll probably need a repair technician. For more info, consult your owners manual, which is also available at
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=fe26abca0a54ad7cbe4ba91bb243a7c2&q=Sanyo+DS31590
Jul 27, 2008 | Sanyo DS31590 31" TV
Sony KDF-E50A11E TV Logo
221 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
