Question about Fluke Networks Fluke T5 600 Elec. Tester Flat
My Fluke T5-600 won't read AC voltage. Everything else works, it's just when you try to read voltage the display goes blank and the red light comes on.
    Master:
  • 678 Answers
More info or picture
Posted on Oct 14, 2013
2 Suggested Answers
  • 678 Answers
SOURCE: Cannot get my Fluke 36 clampmeter to read amps
1. make sure that all buttons can be pressed freely (not stuck)
2. make sure when measuring AC current that you press AC button and AC sigh is on LCD
3. make sure that jaws are closed completely
4. clamp meters use Hall effect and can only measure current flowing through ONE conductor (you cannot measure current around power cord (which has 2-3 or more conductors)
5. when in DC setting and you turn zero knob does value changes (it should)
Posted on Nov 28, 2011
Need the model number of a fluke clamp on meter, serial number is 21530517
try looking for Invoice (it should have model) on it or ask place where you purchased unit from
Mar 25, 2014 | Fluke 321 Clamp-On Meter Electrical...
Fluke 789 error when reading AC voltage at 1000 Hz
specification is given up to 500Hz
this is a process meter - not made for frequencies above 500Hz, you need dmm to measure this frequency
Jan 31, 2014 | Fluke Networks Fluke Fluke 789
Fluke 179 multimeter showing wrong reading in AC, DC voltage, rest every thing working ok
input protection circuit is blown , see if you can find fusible resistor and check for open circuit (should be 1kOhm) - big resistor on the right straight from the Volts input
Mar 15, 2013 | Fluke Networks Fluke 179 Electricians...
My 23 will not work on ac setting
i dont know if this affects the reading on AC but in the back of the meter there are 2 fuses. remove the back cover and check these fuses.
Jan 12, 2010 | Fluke Networks Fluke Multimeter Combo Kit...
Reads random voltage in AC mode
I use a fluke everyday. If it has been dropped, it will need to be recalibrated by fluke. Mine has a range button, try to use a lesser or greater range depending on what range it fluctuates
Dec 20, 2009 | Fluke Networks Fluke 83-V Digital...
Blank Display, using exernal monitor, can see display info w/flashlight, display flashes light at startup
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 03, 2009 | Toshiba Satellite A135-S4407 Notebook
Fluke Networks Fluke T5 600 Elec. Tester Flat Logo
342 people viewed this question
Top Fluke Networks Measuring Tools & Sensors Experts
Vuk B
Trevor Turner
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Fluke Networks Measuring Tool and Sensor Expert? Answer questions, earn points and help others
