Question about NorStar T7316E Corded Phone
How do i change the outbound caller id number on the T7316? several of our users lines are currently programmed with my number as their outgoing caller id number, so their clients keep calling me back instead of them.
  • carrie_greif Mar 31, 2011
    figured it out...it's under the the line access menu. so...
    Feat **266344
    266344
    show
    ext #
    show
    show
    hit next until hit OLI #
    change
    enter new OLI#
    RLS
    Sergeant:
    Champion:
  • 244 Answers
I found this guide that has a lot of information regarding the programming of the Norstar phones..
Hope this helps you!
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
Posted on Mar 31, 2011
    unfortunately there was nothing in the guide to help me with my situation, but i've definitely booked the site to help me with future programming.
    thanks!
How do I unblock my phone number
After you enter *67, you hear the dial tone. Dial the outbound number. Your caller ID is not presented on the receiving end.
After you enter *82, you hear the dial tone. Dial the outbound number. Your caller ID is presented on the receiving end.
Sep 25, 2014 | Lands Phones
Where is the Caller ID for Outbound calls programmed?
Have you resolved this yet? If your CO connection is analog, it's done by your telco. If you have a PRI (T1), then it's in your system's configuration.
Jun 26, 2014 | Nortel Lands Phones
My Nokia 701 cant make outgoing calls. Whenever I try to call someone it disconnects before it even rings and displays "No Answer"
If its a case where you can receive calls and texts, and send texts no prob but you cant call out then its a caller-id problem with your mobile service provider. Ring up the support team and have them reset your caller-id on their end. Once done, power cycle the phone and the phone shoild call outbound no problem.
Aug 19, 2013 | Nokia Lands Phones
My t7316 is no longer ringing at my desk or showing the caller id
You can set the ringer volume by using Feature *80 and use the volume control to change the level. If this does not get your phone to ring again, then the line assignments will need to be reprogrammed.
Mar 19, 2013 | NorStar T7316 Corded Phone
I am configuring a pri ckt in mitel sx200icp i cannot make outbound calls i have programmed pri card as per carrier in form 42 with NI2 - NI2bell have tried all procol variant incoming is fine
It sounds like the outbound Caller ID is not set up properly in form 22. You will need to insert *6 into the dial string. If this isn't set up, many carriers will reject the call as it doesn't see the correct outbound caller ID.
Sincerely,
Mark
Mar 16, 2011 | Mitel PRI Card T1 E1 (9109615001)
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
How do I set up a phone to display caller id? It displays on other phones in the office but not on mine.
To set up call id you need to enter programming2.gif . Programming is done on M7310, M7324, and T7316 sets only. Press the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program call log on. Press the show key (top right arrow)
Press the next key (bottom right arrow) 5 times. The display should say TELCO FEATURES.
Press the show key (top right arrow) 2 times. The display should say CALLED ID: N(or Y)Press the change key til it says Y.
press the release key.
May 03, 2010 | NorStar T7316E Telephone
Outbound caller ID
Telephony configuration might necessary...
Oct 21, 2009 | Aastra Telecom PT-390 for Televantage...
Caller ID does not work until call is answered.
Sep 24, 2009 | NorStar M7310 Phone
Caller id recall
To redisplay the Caller Id Number, press the Line button again.Caller ID Scrolling is possible if you have a MIF-F(C)-10 card in the system and you have a Scroll key programmed on the phone. If you need further assistance, let me know.
Aug 27, 2008 | NEC Electra Professional ETW-16DC-2
NorStar T7316E Corded Phone Logo
299 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
