Question about Panasonic KX-TGA101S Cordless Handset
Got a new set of handsets but the base doesn't recognize them...
    Master:
  • 346 Answers
Hi - Are you sure you have followed the following procedure exactly?
Have the correct base units for these handsets which are:
KX-TG1032, KX-TG1033,
KX-TG1034, KX-TG1035
Are using NiMH batteries
That have been charged for at least seven hours
Have followed this procedure:
Good Luck,
Mikeywaf
Posted on Mar 31, 2011
How do I add a handset to my Panasonic cordless phone?
just add the extra handset then follow the set up procedure as explained in the user manual
the base set has to recognize each new handset and allocate it a hand set number
all explained in the user manual
Oct 30, 2016 | Panasonic Lands Phones
Are thee any Binatone handsets compatable as extra handset to add to Binatone symphony 3325 unable to get new handsets but main answering machine and handset are still working
with cordless phones the problem is that the hand sets have to be recognized by the base station ( paired) and unless you have the exact hand piece make and model this pairing and recognition will not happen
if you can get 2nd hand units for the 3325 base then the base will accept them ( any number of additions ) but if the hand piece is different it will not work
you you need extra hand pieces then it may be best to consider a new system where you can buy extra phones and chargers
Jul 13, 2016 | Binatone Lands Phones
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
Cordless handset doesn't work, a new battery doesn't fix the problem. Where can I purchase a compatible cordless handset to work with this phone 27958GE1-B
Each handset is programmed or set to the matching frequency of the base phone and so if the handset does not mesh up then the intertransmitting frequency is not correct and is not locking.
Hence you need to check up with your dealership/ support center of your make to confirm and order a new one or the cost of a new cordless phone will work out cheaper which must be considered.
Aug 19, 2011 | Cell Phones
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Sep 27, 2010 | Panasonic KX-TG2356 Cordless Phone
I have a Uniden DECT 6.0 phone set. I damaged one
On the base, open the menu and select Register Handset. The display should say Handset Registering.
On the handset you want to register, press and hold # until the handset display says Handset Registering (about 2 seconds).
1.
2.
DSL filterTelephone cordTelephone wall jack
45
In about 30 seconds, the handset display should say Registration Complete. Press Talk/fl ash and make sure you get a dial tone.
If...
Try...
you don't hear a dial tone
the display says Registration Failed --
Making sure the handset is fully charged, then start over at step 1.
Sep 07, 2009 | Uniden DECT 6.0 Cordless Telephone...
Philips CD240 2nd phone wont connect - keeps saying searching
Hi, I solved this issue this morning. What you cannot confuse here is that handset and base. To do the registration successfully, the both must be in "Registering" mode. First, to get the base in the registration mode, you have to press <page> (a paging function for handset in case you cannot find where they are - usually button that says <page>or speaker with sound symbol on the base) more than 5 seconds, then the base is in the "Register Mode"(though you will hear no beep). You can then go through the procedure you describe on the handset and the handset should beep with assigned number no more than 10 seconds after it flashed "Waiting". The above, however, works only if the Base is still functioning. In my case, sadly, the base was more likely dead (if I press any button on the base, i.e. answer phone etc., there is no response). Hence I went and bought a new cheap GAP compatible BINATONE 1800 Single at Comet (14.99). I then set up the base, put it in the registration mode as per the BINATONE instruction. Then on the Phillips CD240 handset and gone through the above registration procedure... and Voila! It worked. Now I have a brand new base that came with 1 handset of its own, and 3 additional CD245 handsets which are all registered with this base. So far, the sound quality is good and they retained all the telephone numbers registered with the handset. The BINATONE base came with 12 months manufacturer's guarantee so I am sorted with the base problem for at least a year, which is nice. I hope this is helpful. Best, Ken
Feb 03, 2009 | Philips Lands Phones
Dead Uniden DCT5280 Handset
if battery just replace battery but the head sets are compatible with other handsets of same ghz say 2.4 you just gotta set in base and let base recognize new hand set these phones are practically built the same way but only with new technology
May 03, 2008 | Uniden Cordless Phone
Adding new expansion handset
You will need to register it to your base station before it will work. You do so by holding down the registration/page key on the bottom of your base for a couple of seconds, and then grab your SL30 and push Menu, scroll down to the option of Handset settings, press OK, then scroll to "registration" and push OK, select base station 1, press OK, then enter the default pin of 0000 and press ok. Repeat these steps if first not successful. You can download a manual for free on our website at www.cordlessrepair.com
May 21, 2007 | Siemens Gigaset SL30 Cordless Expansion...
Panasonic KX-TGA101S Cordless Handset Logo
369 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
