Question about ViewSonic VX2235wm LCD Monitor
I have a viewsonic monitor model # VX2245wm. It will power up at times a stay on until the computer goes to power saving mode or the screen saver come's on. Then it power's down and won't come back on for a while.
  • 11,361 Answers
It does the same when using it with another PC?
Otherwise it may have bad caps as shown in my pictures here, very common problem.
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 31, 2011
Testimonial: "Great helps alot"
Hey I have a viewsonic VX2245WM and my problem is that when I turn my computer on the monitor light goes red-ish like a red light that is starting to fade away and the screen is completely black like its...
Almost the same chassis as VX2235.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 19, 2010 | ViewSonic VX2245WM LCD Monitor
I have a Viewsonic VX2245wm or VS11349, Works and then it goes black for 2 to 4 sec then runs for 10 to 15 min and goes black
Look at the power supply section for bad caps first, see example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside, it can also be caused by bad inverter circuits or bad lamps.
Feb 20, 2010 | ViewSonic VX2245WM LCD Monitor
I have power going to my Viewsonic VX2245wm but no image
You need to check the internal power supply to see if your capacitors have popped. Even though it may show power, the portion of the power supply that powers the LCD itself may have been damaged ::
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX2235W/?action=view&current=DSCF1718.jpg
Jan 10, 2010 | ViewSonic VX2245WM LCD Monitor
The monitor goes blank after a few min, it comes
Are you sure that your computer isn't just going into power saving mode? Not sure what operating system you have but go into the screen savers tab or video properties and find out how your system is set up for power saving It may be starting before your screen saver does so the monitor would just go black.
Dec 18, 2009 | ViewSonic PF775 17" CRT Monitor
My ViewSonic monitor just blacks out for no reason
It could be a setting you could have done on the "Power Saving" settings under "Screen Saver" settings, if you have Windows XP. Like "Turn off monitor after" a certain time. Even if you don't have Windows, please check the Power Save settings.
Jan 29, 2009 | Mag Innovision LT976S 19" Flat Panel LCD...
Viewsonic monitor shuts down
try check your screen saver setting, it might be the time of screen saver to appear when PC not used, screen saver might be in blank.cheers.
Jan 21, 2009 | ViewSonic VA1912w 19" LCD Monitor
Monitor won't stay on
Your computer may be in screen saver mode, it has instructed the monitor to go to power saving mode, or the the monitor's video cable is not properly connected to the computer. Another possible cause of this is a locked-up or in-operative computer since the computer is what supplies the monitor with all the display data or information. Move the mouse or press a key to de-activate the screen saver or power saving mode. Check the monitor's video cable and make sure it is snugly connected to the computer. To see if the computer is operating properly, press the CAPS LOCK key on the keyboard repeatedly while checking the CAPS LOCK light. If the light is not turning ON & OFF, the computer is non-functional. Contact your computer manufacturer for help.
Dec 02, 2008 | Computers & Internet
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
Power saving
Right click your desktop, click properties, click the screen saver tab, it'll say monitor power at the bottom, click power then choose which option you want. Good luck.
Aug 14, 2007 | ViewSonic VE155b 15" LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
608 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
