Question about Refrigerators
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting drip pan at the bottom of the fridge is empty. It seems like there might be a clog. Is that possible and if so, how do I remove it?
  • gmmmaine Apr 15, 2009
    I have an older Whirlpool refrigerator with top mounted freezer and water is leaking into the fridge and pooling on the shelves. I understand this is mopst likely caused by a clog but I don't have the owner's manual and can't figure out what I need to take apart to fix the problem. Can anyone tell me waht I have to take apart to fix the problem?
    Thanks
    Merry
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Posted on Aug 11, 2008
Leaking water
Did you inspect if the hole in the drain inside the fridge at the bottom is not blocked? Try to clean it with a swab. Sometimes this causes a "leakage" of condensed water.
Dec 14, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
I need an owner manual for the whirlpool refrigerator with the model number ET14JKXDW10. Inside fridge leaking water
Water inside fridge usually due to blocked drain tube, clear with drinking straw and check door seal and clean condenser
May 09, 2012 | Whirlpool Refrigerators
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
All items in freezer were defrosted when I opened the door this morning. Fridge is semi cold.
Hi
Some leaking water refrigerator helps....
  1. My older style Amana freezer on top refrigerator is leaking inside
  2. My refrigerator is leaking water inside
  3. My refrigerator is leaking water onto the floor
My refrigerator is leaking water inside the fridge:
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
May 30, 2009 | Kenmore Refrigerators
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Refrigerator leaking water
Try cleaning out the hose (on the exterior rear). This is the drain from the condenser to the evaporator pan.
May 12, 2009 | Whirlpool 18.8 cu. ft. Top Freezer...
Water leaks inside fridge from top freezer
check your gasket on the refridge door see if it has any rips or you have a blocked drain in freezer
May 02, 2009 | Refrigerators
Fridge leaks water on the inside, is not condensation
Hi!!! Your drain line is plugg, also there might be some dirt plugged so remove the evaporator panel are clean the drain line..deb5a30.jpg
Jan 04, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water Leaking
The defrost drain is clogged up. I can't say much more because you didn't supply the model #
This may be a drip catch that you can get to from inside the refer or it may be the big tube on the backside of the box.
You may have to take the freezer apart and use a hair dryer to thaw out the ice.
Model numbers are important!
Jan 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
654 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
