Question about HP Compaq DVD Drive
If i insert a CD/DVD disk, my laptop will not read this. I work on a windows vista, HP Pavalion DV6000. I've tried everything, nothing works.
  • David Petry Mar 31, 2011
    Did you try eneableing and check it in device manager?
  • 79 Answers
Hi, make sure that the cd/dvd rom is detected by your computer. You can check that in your my computer if there would be a disk drive. If not, check the connection inside your cpu or if your cd/dvd rom needs to be installed first. thanx
Hope this one works.
Posted on Mar 31, 2011
  • HP Master
  • 27,725 Answers
Make sure that the dvd is getting enough power test all leads that are attached to the dvd including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Inspiron b120 cd/dvd drive wont work
probably need new one But try this go to control panel then device manager then in the D's is your dvd there or is there a mark by it this may mean the driver maybe missing right click on the DVD then click on update driver, search automatically & hopefully it is found
Feb 01, 2015 | Computers & Internet
DVD/CD-ROM drive not working. Drivers were reinstalled and still not operational. Message received that there is a problem with the registry - how can this be fixed?
Find a "bootable" CD-R disk (Ubuntu Linux, Microsoft Windows Vista, Microsoft Windows 7) and restart your computer, and tell it to "boot" from the disk inserted into the CD/DVD disk. If it reads from the CD/DVD, then the hardware is OK. If it cannot read the disk, then it's time to replace the "broken" CD/DVD device.
Aug 02, 2010 | HP G60-230US Notebook
I have a hp pavalion dv6000. It is not coming on.
there is a motherboard issue with this model. hp did offer a free repair on the motherboard.If you still have warranty, then you will need to contact hp to get your laptop motherboard repaired. they also offered an extended warranty due to this problem, you will really need to contact them ASAP so that you don't loose out, cause the motherboard replacement cost is around $600USD.
Sep 25, 2009 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 won't start!!!
Is your laptop one that is included in the recall/free warranty repair service? Check it here.... there are a LOT of known issues with those HP laptops!!
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277&printable=no&encodeUrl=true&
Try checking here and see what you can find.
Jul 06, 2009 | HP Computers & Internet
Hp dvd/rw does not read discs
If the CD or DVD disks you inserted work in some other reader, then your reader is the problem -- even though it is properly connected to your computer, and Windows has the correct device-drivers, it is the "hardware" that is the problem.
When you insert a disk, rotate it to some position, i.e., top-lettering goes in first, and close the drawer. Do you hear the drive start to spin the disk? Open the drawer. Is the disk in the same (non-rotated) position? If so, then the motor that spins the disk is the problem. If the disk does spin, but nothing happens, then it is the "laser" part of the mechanics that is not working.
Replace it.
Apr 21, 2009 | LG GSA-H55N DVD-RAM Burner
I have using vista os with my pavilion dv6000 entertainmen laptop
Hi there.
What you want is the intel matrix storage manager for theextra drivers so XP install can see the SATA drive. Download it fromhere and please make sure you read the read me text on how to set it up
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2101&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go!
Good luck and thanks for using FixYa!!
Apr 09, 2009 | HP Computers & Internet
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Hp Pavilion dv6000's dvd-rw won't work
You do need to take out the high and low filter in the string in the registry. Also remove the same filters w/ a .bak extension. I own a large computer business and we see this almost daily in XP and up.
Feb 08, 2009 | Toshiba Satellite A135-S2386 Notebook
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
May 01, 2008 | HP Pavilion dv6000z Notebook
HP Compaq DVD Drive Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
